Trouble downloading & opening files Corel X3
Hello all,I am having trouble downlaoding drawings from here.I am using corelx3 and some files work but most don't.I keep getting error messages.If any one has any ideas I would sure appreciate it.Thanks Cambo
Re: trouble downloading files
try IMPORTING ALL FILES Most are DXF files and you should bee able to import (NOT OPEN) Will not be able to import PMC files because those files are Special? to Plasma Cam.Hope this helps
Darrell
Darrell
Hey Darrell I gave that a try but no luck.I could open the garden cat by Jason no problem so Im not sure whats going on.I will keep trying.Thanks for your help!!
- plasmajoe
I have noticed that when I export my drawings into DXF and I am using any AutoCad from 2007 to 2010 many of you can not view them, I am now saving them as an earlier version and that seems to work fine. I am not sure why that is. I do not use Corel so I would not be able to help you out more Cambo.cambo wrote:Hello all,I am having trouble downlaoding drawings from here.I am using corelx3 and some files work but most don't.I keep getting error messages.If any one has any ideas I would sure appreciate it.Thanks Cambo
