sheetcam tng problems
_Ogre
Post by _Ogre »
plasma test.dxf
plasma test.dxf
(53.01 KiB) Downloaded 111 times
plasma test.dxf
plasma test.dxf
mrt bronco3.dxf
mrt bronco3.dxf
(62.31 KiB) Downloaded 78 times
mrt bronco3.dxf
mrt bronco3.dxf
or so i believe i have a problem within sheetcam.
i am new to cnc in general, a total newb to cnc plasma cutting. just did a test of our new bulltear 4x8 w/ dthc, mach3 bladerunner and powermax 65. the table was a turn key and came loaded with all the mach3 setup done. the torch fired and cut the shapes i had drawn just out of scale. i am fairly well versed in autocad 2000 and use it for all technical drawings. i had drawn simple shapes ''plasma test'' 2- 2'' circles and 2- 2'' squares and an arc thingy. the circles and squares cut great, they were just 4.5'' across instead of 2'' as drawn. any ideas of what i did wrong?
plasma test
so i moved on to my first real project. ''mrt bronco3'' is a couple of simple signs to be cut out of 10 ga mild steel. it took me a few times to get all of the arcs drawn to make 1 pierce per letter, when i run sheetcam it has the outside of one sign cut first then the letters. then sheetcam jumps around cutting some letters in the 2nd sign then some letters in the 3rd sign, then the outside of one sign and then the rest of the letters. how do i move pierce point and the layout of the cuts?
mrt bronc3
i'll upload both plasma test and mrt broco3 dxf files
_Ogre
Re: sheetcam tng problems
Post by _Ogre »
also can any one tell me how to do a test draw? or test the cut path without the torch on?
i tried to run the gcode in mach3 with the torch off and z axis zeroed out one half inch above the water table slats. the z axis went past zero and traveled below the slat surface.
Metriccar
Post by Metriccar »
Do you have pics of those test squares? I'm interested in seeing them. It sounds like you had THC on so the torch tip tried to go down and hit the material.
_Ogre
Post by _Ogre »
i had the thc off on the mach3 screen. i figured with thc off the torch would go to pierce height and no farther. i also had the torch off electrically and on the screen.
abmagrum
Post by abmagrum »
hey Ogre
here are some tutorial videos on sheet cam and mach see if they help
http://arclightcnc.com/training.html
there free no catches
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
SeanP
Post by SeanP »
Not sure about the scaling problem although you can alter the scale when you import the drawing to sheetcam, doubt you will have that set wrong though, does it move say 1'' when you enter 1'' into mach manually?
Your drawing loads fine and to scale into my sheetcam
To do a test run I just turn off the power to the plasma, turn off thc in mach and away it goes.
To keep the parts cutting together you might change the cut path settings in the operations window.
Sean
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Largemouthlou
Post by Largemouthlou »
I Put your file into Sheetcam tng and the square and circle measure out to 2" so you may have to retun the steps on the machine for some reason, also like said ck the scaling.. Need to get ahold of Bullteer and have them walk through this with you.
Also you have open pathes on the R's whish is causing sheet cam to get a little confused, fix the R's and all should be good in the cut order.
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
_Ogre
Post by _Ogre »
thanks for the feedback people. first thing i should have done is to run a scale on the table and check my travel. i'm new to this and have severe crs at times :D
largemouth; thanks for checking my dxf in sheetcam
_Ogre
Post by _Ogre »
abmagrum wrote:hey Ogre
wow. i wish i had seen those videos a month ago. explained a lot in mach3.
never could get the the cut path to zoom. thanks for that link abmagrum :mrgreen:
Return to “SheetCam”
