25 pc. of these.
SpartanKen
25 pc. of these.
Post by SpartanKen »
I have a guy that wants me to quote 25 of these peacock feathers. 3' long x 1' wide.
What would you quote for 1 and for 25 of them.
Cut from 16 gauge. unfinished.
Ken
SpartanKen
Re: 25 pc. pf these.
file is not complete, just started cleaning it up.
erickmff
Post by erickmff »
Are you sure that it's just 3 inch long? The details would be too small to be made with Plasma.
Here in Brazil I usually quote:
Cutting Time: 600 BRL/Hour
PLUS
Desingning Time: 600 BRL/Hour (Almost all drawings I can make in less than 10min)
PLUS
Carbon Steel: 4 BRL/Square Kg (I pay 2.50 BRL/Kg)
OR
Stainless: 18 BRL/Square Kg (I pay 13.7 BRL/Kg)
When a customer send me a CLEAN file and material, I just quote him the cutting time.
My complete Setup: White Martins Autocut 3000 - Hypertherm HPR260XD, Automatic Gas Console, ArcGlide THC, Edge Pro, ProNest 2012.
SpartanKen
3 feet. lol, where did I mess up and put 3 inches?
SpartanKen
I had to create the file, it was not sent to me, I just wanted to get on here to get a quote.
Ken
erickmff
Re: 25 pc. of these.
Post by erickmff »
Sorry, I just missundertanded, I'm used to work with Metric Units. 3 feet = 900mm
Does your Cam Software calculates the cutting time?
How much time did you take to draw?
SpartanKen
I'm sure it does... it hasn't arrived yet. I ordered my table a while ago, it will be here on Wednesday (I hope).
Ken
SpartanKen
ok, can anyone plug this in and tell me how many inches there are in one piece, how many pierce points (I think about 38).
Ken
cnchybrid
Post by cnchybrid »
Sorry to say but this file is horrible for plasma cutting.
I plugged it into my own software for wood. Used a .030 bit simulating a fine cut consumable from hypertherm with a feedrate of 100ipm. The software said 19 minutes roughly.
The end result was crap. Way too much detail in that feather and is not worthy of wasting metal on. Clean it up if you get the job with a lot less detail.
Hope that helps
SpartanKen
Good to know, without any time on a machine, I have nothing to go off of. Without knowing the true limitations of the machine, I'm relying on others to steer me in the right direction. I imagine I will be wasting a few sheets for my learning curve.
OK, so the main issue here is the lines are to close/thin?
Ken
Mr.Dirt
Post by Mr.Dirt »
This piece is way to detailed to be your first cut.
I also agree that it will fall apart when you cut it.
A laser cutter could cut it ,I would think.
If you would scale this file up to 3ft, you should be able to cut it without much problem. Thanks to RBRAGUE for the file.
http://plasmaspider.com/viewtopic.php?f ... ther#p5933 Go here for the picture, and file. :D :D :D
SpartanKen
that is the scale I want, 3 foot for the one I created. Will the file I upladed work at 3 feet? I really don't see the difference between the two. What am I missing here?
Ken
SpartanKen
comparison
SpartanKen
I guess the one on the right is slightly thicker, but not much.
SignTorch Vector Art
Post by SignTorch Vector Art »
you should practice, tune the torch, and use kerf compensation, to get this right....
not to scale
WOW, that's a very nice feather! :D :D
SpartanKen
Thanks again.
I told the guy I'll have to pass, since I have no idea what to quote it other then the cost of material.
bhamer62
Post by bhamer62 »
good move, the one you posted is absolutely a file that needs to be laser cut. The one Signtorch posted would cut very nicely on a plasma though
