Wrapping Text Around Object
This what Im tring to do. I want to add REUNION to the top (outside the circles) and 2010 to the bottom(outsidethe circles). Would also like to know if there is a way to put it inside the outer ring. I just cant figure out how to move the letters independently. Tanks for any help.
- Attachments
- renuion2010.cdr
- (115.25 KiB) Downloaded 150 times
- renuion2010.cdr
Re: Corel Design questions welcome!
Thanks leatherhands I will try that when I get back to my machine. I would love to know the faster easyer way. Work smarter not harder rite.
Re: Wrapping Text Around Object
wrenchhead - Here is your design with a different text on top and something in the lower ring. Ther are many different ways to do your design. Thought I would give you something to experiment with. - John
That is good work and something i can work with. Thanks for the help. I worked with my design and changed it up some. this is what i came up with.
- Attachments
- reunion 2010.cdr
- (19.64 KiB) Downloaded 103 times
- reunion 2010.cdr
wrenchhead - Could you post the file in ver.11. That is the newest I can open - John
Here it is srp sorry it took so long.
- Attachments
- reunionsign1.cdr
- (19.57 KiB) Downloaded 116 times
- reunionsign1.cdr
wrenchhead - Appears you have that task down pat. What I find with an intricate font like "Reunion" if one's machine is loose or if the part is small much detail will be lost. When you finish the project upload a picture of the piece to the Project Picture Gallery. - John
desk engrave can also wrap text at any radius top or bottom must put - before radius . help will help you with placment of text either top or bottom . I learned this from Loyd thanks again Loyd
