Need help converting low quality image
hondafreak08
Post by hondafreak08 »
Hey guys i am new to this forum and corel draw.
It has been a big help. What i am running into is this "black and white" low quality image also has a gray area around the lettering. Causing the Sprocket area of the image to come out nice and the lettering to look wavy
Can someone please show me/ trace this image.
Or send me to a link to help explain, id assume there has to be an easier way than just hand tracing
muzza
Re: Need help converting low quality image
Post by muzza »
A low quality image is always going to be more challenging and normally require some addition manual manipulation to get right.
What I have done here is used the Corel X5 trace feature basically as explained in this forum by Gamelord but first to get rid of the grey I have used Bitmaps> Mode> Black and White> line art to create a true black and white image.
Prior to exporting as a dxf I have used Arrange> Ungroup all to select and remove drop shaddows, two of the letter drop shaddows were connected to the letters so I had to manually remove those and the exported to dxf.
Still not the cleanest but the initial image wasn't great. Also needs bridging.
Murray
whitmans.dxf
(169.33 KiB) Downloaded 98 times
whitmans.dxf
whitmans.dxf
whitmans.dxf
hondafreak08
thankyou for the help,, I watch the videos and theres always something just a little different with the image im using so that one step is what stumps me
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Here's a little something to get you started. I drew this in Coreldraw "cad style" and I wanted to draw the whole thing just for the practise but I have to move on to other more pressing duties. I drew it over the top of the bitmap image to approximate the scaling of the "gear teeth" curves.
If you're going to do a plasma cut for this image, always consider if everything will hold together in one peice when it's cut out. I see so many drawings and end up wondering how they will be cut and end up as one single peice.
Keith.
whitmans ride shop.cdr
(23.81 KiB) Downloaded 82 times
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
hondafreak08
With this drawing its being cut into a rectangular sheet with a light behind it... Shouldn't require much work besides the lettering . Also thank you for the help
SignTorch Vector Art
Post by SignTorch Vector Art »
This is a good example
youtube vid
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
Thanks for doing that little video Signtorch, I like the method you used to create the gear. FAR quicker than the way I did it.
Keith.
LinuxCNC
Coreldraw 2019
