I have attempted about 10 squares redrawn about 5 times with no broken lines and every time my torch gets to cutting good and then it skips. What is causing this problem??? Burn tables has been no help in clearing up this problem for me. I am getting fustrated and I am new to this. Really hoping I can get this problem solved today. Any help would be appreciated.
-I am using a Hypertherm 45 with a burn table with dhc.
PLASMA SKIPPING DURING CUTTING
- cstroke
Re: PLASMA SKIPPING DURING CUTTING
Try turning your height control off and cutting one.. manually keep your height around 1/8"..
If it cuts then it's a problem with your height control.. This might not be your answer but you can start eliminating problems..
Is your ground hooked directly to the piece you are cutting?
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Low air pressure?
How did you end up fixing this problem??? I’m having it happen to me now
