Brand new - Torchmate/Cad
Torchmates software related questions and tips can be posted here
burbasj
Post by burbasj »
Hi I am a new guy here. I am using Torchmate/Cad and I am haveing a difficult time trying to do a bridge weld
on some lettering like O's and 0's ect. Is there a trick I need to learn . Thanks for your help.
jmsrbrt
Re: Brand new to the world of Plazma and your forum
Post by jmsrbrt »
Can you expand on "bridge weld"? I have the TMCAD and can try to help you. Bob.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Cotton
Post by Cotton »
Quick way is to make a box and move it over the Zero and O's and then use your weld function to split it in half.
DLE
Post by DLE »
Actually, the easiest way is NOT to weld rectangles.. the best way is to select the letter you want to link (make sure that the inside and outside is a "path") and go to Layout in the menu bar, down to common line cutting and use the inclusion function. Select the start and end points, and it will simply create a bridge without having to use multiple steps with welding. You can even specify the width of the bridge by going to your Cadlink.ini file in the c:\Torchmate folder, and changing the parameters under "Hotwire Setup" You will see a number following both Inclusion and Chaining
hope this helps!
burbasj
Post by burbasj »
Thanks for the info I'll give that a try.
burbasj
Post by burbasj »
jmsrbrt wrote:Can you expand on "bridge weld"? I have the TMCAD and can try to help you. Bob.
Hi Bob This is what I do I grab a letter change it to a grafic , then I selecta rectangle and place it where I want to
make the cut and adjust the size as needed. Then I select the entire drawing and make a path. then I go to my
weld choices and select basic weld. After all that then I select a show fill and that is when I see if my box is just a tiny bit small it shows my red cut lines. and if my box is a bit too large it shows a white void. and then AND THEN
I throw the computer. ha ha Just Kidding.
aicomp
Post by aicomp »
Some excellent Torchmate Cad tutorials here:
http://www.pirate4x4.com/forum/showthread.php?t=963784
They were done by the TM support folks.
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Return to “Torchmate Software”
