I will soon be purchasing a HYPERTHERM PowerMax 85 to be used with a CNC Plasma Table.
I will be using CandCNC's BladeRunner Dragon Cut System with the Advanced Connection Kit.
That includes the Current Probe and the RS-485 SIM Kit.
After I have all this hooked up to my PowerMax 85, with a 25' machine torch attached to my CNC Plasma Table. I now decide I want to cut something like a "birds-mouth" in a piece of pipe with a 50' hand torch connected to my PowerMax 85, how complicated will it be to make the machine torch to hand torch switch out.
The PowerMax will stay stationary / mounted to a stand near the Plasma Table. . .
Will I have to disconnect / unplug all my connections between my CandCNC controller and the Powermax or just simply swap the torch connections.
I know a 50' hand torch will cost me about $600.00, but that is cheaper than buying a second plasma cutter for hand held use.
Any problem solving comments appreciated . . .
HYPERTHERM Machine & Hand Torch
- CNCCAJUN
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: HYPERTHERM Machine & Hand Torch
As long as you can leave your plasma cutter where it is, I think it's as simple as changing the torch leads. (which is a quick-connect deal)
That's what it's like for my Powermax 45 anyway, which does not have the serial port for communications--so that's the only possible sticky spot.
Unplug MT Plug in Ht nd start cutting everything else can stay hooked up atleaast it does on my pm 65
I think the cutter knows which torch is pluged in, smart
Mike
Mike
All you need to do is unplug the quick disconnect machine torch and plug in the quick disconnect hand torch. The machine start signal will not fire the hand torch....assuming that the cnc machine is interfaced through the rear panel CPC connector. I have a Powermax85 on one of my cnc machines....I switch from the machine torch to the hand torch often to cut up the metal skeleton for easy removal from the table.
Jim Colt Hypertherm
Jim Colt Hypertherm
- CNCCAJUN
Thanks, I was under the impression that I would have to disconnect the Rs 485 Serial Connector and/or the CPC connector that will be tied to my CandCNC Control Panel . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
I would turn it off & probably wouldn't hurt to unplug it. Not sure if you can change it out powered up but no longer than it takes to flip a switch, why risk it?CNCCAJUN wrote:Thanks, I was under the impression that I would have to disconnect the Rs 485 Serial Connector and/or the CPC connector that will be tied to my CandCNC Control Panel . . .
Do you have to turn off the PowerMax to make the torch switch over?
When you unplug the torch disconnect the power supply will interlock out.....it will not refire until another torch is plugged in and you re-cycle the power switch. There are a lot of safety features engineered into the Hypertherm systems.
Jim Colt Hypertherm
Jim Colt Hypertherm
- CNCCAJUN
Thank you Jim . . .
I think we need to establish a new rule . . .
Tom with CandCNC and Jim with Hypertherm shall never be allowed to travel together . . .nor should they be allowed to be in the same building at the same time . . .
Sort of like the President and the Vice President . . .
This will protect the livelihoods of 100's of Plasma CNC operators throughout the world . . .
Thank you again . .
Thank you again . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
