Resizing a full DXF file
AMF
Post by AMF »
Have a DXF file but all measurements need to be enlarged by 25x the size. I have manually computed each dimension and increased it by 25x manually, but its getting so much overlap, based on the larger pieces and smaller pieces becoming lost under the larger pieces, etc. How can i enlarge the whole file at once, instead of each individual piece one by one.
As always thank you
EMACHINE software
Joe Jones
Re: Resizing a full DXF file
Post by Joe Jones »
Post the file here. 25x? It sounds like it was drawn in METRIC (millimeters) and you need it drawn in IMPERIAL (inches.) 25.4mm = 1 inch
You must GROUP a drawing if you are going to scale the entire thing.
AMF wrote: Mon May 05, 2025 4:14 pm Have a DXF file but all measurements need to be enlarged by 25x the size. I have manually computed each dimension and increased it by 25x manually, but its getting so much overlap, based on the larger pieces and smaller pieces becoming lost under the larger pieces, etc. How can i enlarge the whole file at once, instead of each individual piece one by one.
As always thank you
EMACHINE software
What software are you working with?
weldguy wrote: Mon May 05, 2025 8:15 pm What software are you working with?
eMachineShop
https://www.emachineshop.com/
AMF
Post by AMF »
Thank you all, for the help. I will try both next time inthe shop.
As always, thank you
AMF wrote: Mon May 05, 2025 9:08 pm Thank you all, for the help. I will try both next time inthe shop.
:Like :Like :Like
Deezl Smoke
Post by Deezl Smoke »
Interesting. In Qcad I just highlight the whole part, click modify, scale, and go to whatever scale factor I want, then click to save original or delete it, and it's done. Cool to see other programs that people use. Emachineshop is probably a very versatile and professional level program.
Deezl Smoke wrote: Tue May 06, 2025 8:22 pm Interesting. In Qcad I just highlight the whole part, click modify, scale, and go to whatever scale factor I want, then click to save original or delete it, and it's done. Cool to see other programs that people use. Emachineshop is probably a very versatile and professional level program.
EMachineShop is a pretty basic program and is mainly offered for free so that potential customers can design their parts and send the files to EMachineShop (the company) for making the parts for the customer.
I have used both programs and I would say QCad is a more "full featured" cad program. Both programs are fun to use.
BTA Plasma
Post by BTA Plasma »
25.4 Millimeters is equal to 1 inch. You may just need to import it as metric without any scaling.
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
