fire pit bends
fire pit bends
hey, i'm new to cnc plasma can someone explain to me the best way to bend the sides of a fire pit. i have seen where you can cut reliefs but can you bend like 10 gu without a bending machine?? love this forum thanks for your help
- Scratch
Re: fire pit bends
Bending wide pieces of 10 gauge without some sort of brake, press or relief cuts is going to be very hard. I'd make relief cuts if its wide pieces like for a fire pit. If it's small pieces like 4" or so, just put it in a vise and bend it but wide pieces like that are going to need some help.
You could also go with something like the SWAG press brake kits like these:
https://www.swagoffroad.com/collections ... brake-kits
but for firepits where they don't have to be airtight, I'd just do relief cuts. Those also help make the bends exactly where you want them to be unlike bending without them.
Re: fire pit bends
I agree with Scratch. I typically cut slots along the bend lines with a slot width of anywhere from 50% to 100% of the material thickness.
Re: fire pit bends
Ah yes, the metal origami technique. Have used relief cuts for years, works like a charm. As David says the thicker the material the wider the relief. Practice on some scrap and get the reliefs dialed in for yourself.
Re: fire pit bends
thanks for the help, i'll try it on scrap
Re: fire pit bends
Here are a few examples of some pieces with slots along the bend lines. The first one is just a test piece I did to figure out the correct slot width for 11 ga. steel.
This one was a replacement bottom to fit a friends fire pit.
I started out by making a cardboard template and fitting it to the bottom of the fire pit with the rusted out bottom.
Then I modeled it up with SolidWorks to create the dxf file for cutting.
I cut long slots with only short tabs holding the fingers/pedals to the main body, and was able to bend each pedal by hand (a little bit at a time to try to keep then even).
This is what it looked like fit into the fire pit bottom. I welded it in.
Re: fire pit bends
Pretty awesome example David. Looks great!
Re: fire pit bends
Thanks Plasmanewbie! That was a fun project and probably the first time I tried cutting some relief slots for bending. It worked out great and my friend was happy with the result.
