drawing points in Corel Draw for a drill routine?
- Tristar500
Can anybody tell me howto add points to a Corel Draw file so I can use them as drill points in SheetCam?
Thanks!!
Thanks!!
50X50 plasma w/ pneumatic drill- own design
Mach3,4 SheetCam, CorelDRAW 2020
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60 Plasma
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
He who is without oil shall throw the first rod
Compressions 8.7:1
Hypertherm 350
Several mig welders
Compressions 8.7:1
Re: drawing points in Corel Draw for a drill routine?
I know of no way to create a single point using CorelDraw. Design Edge and BricsCAD both have a Point tool.
Just draw a circle that is .001" in diameter and that will work.
- Scratch
I use Corel draw, and when I need to do a point, I just create a line, then zoom in on it really really close, then drag one of the end points until it’s right next to the other one. Zoom out and boom… single point.
plasmanewbie wrote: Mon Dec 18, 2023 11:57 am Just draw a circle that is .001" in diameter and that will work.
Scratch wrote: Mon Dec 18, 2023 5:49 pm I use Corel draw, and when I need to do a point, I just create a line, then zoom in on it really really close, then drag one of the end points until it’s right next to the other one. Zoom out and boom… single point.
For "drill points" for cnc machining, I would draw the small circle as Plasmanewbie has suggested. That way - the drill bit, endmill, etc. will locate on the center of the circle. It this is just for marking sheet metal with plasma for subsequent manual drilling of holes, then either method should work fine.
- Tristar500
I've tried a few of the suggestions here but Sheetcam doesn't seem to identify tiny circles etc at points.
Am I missing something here?
I don't use SheetCam for this sort of stuff, but I do expect that it is capable of using small circles for drill points as SheetCam is also used for cnc machining tool paths where it could be drilling holes.Tristar500 wrote: Tue Nov 19, 2024 4:20 am I've tried a few of the suggestions here but Sheetcam doesn't seem to identify tiny circles etc at points.
Here is a thread with some information on drilling holes using SheetCam.
viewtopic.php?p=241803#p241803
