Hello all.
I was wondering if anyone else is using the Hynade Cut60 machine.
I am looking for some baseline cut settings. I have not had the chance to spend much time with the unit to figure out the settings yet. I am hoping someone has some setting to help give me a jump start.
Hynade Cut60dn Cut Settings Chart
Re: Hynade Cut60dn
That is a new plasma cutter to me, likely won't find anyone with settings to start with but it's easy to develop a settings chart of your own for the thickness and type of material you cut. Start with a cut height of around .060", leave the THC off if you have one, and start cutting a few straight lines. Find the maximum speed you can cut before it will no longer cut through, then back it off a little and this is a good starting speed for that material. Inspect the cut for square edge, dross formation, and if you are satisfied you can introduce the THC into the next few cuts and find the voltage value that will maintain a .060" cutting height. If you are not satisfied with your edge and dross let us know what you see and we can alter your cut height in hopes of improving it before introducing the THC into the mix.
Re: Hynade Cut60dn
Re: Hynade Cut60dn
Thank you!
I don't know why I am just now seeing this.
Re: Hynade Cut60dn
You can modify your notifications which will help.
Visit the User Control Panel by clicking on your username in the upper right side and from the drop down select the 1st option User Control Panel.
In there click on Board Preferences and the Email Notification Options and check the boxes that apply to what you want. See below.
