Help with logo
tomloewen
Help with logo
Post by tomloewen »
I'm hoping someone can convert this logo to dxf. Target dia. is 36"
The problem is that the resolution isn't the best.
Tom
ponk.svg
ben de lappe
Re: Help with logo
Post by ben de lappe »
I attempted to increase the resolution of this image to offer something a little better to work with at least but was not successful. Went online searching for a better image but the one I found on their website faired no better. Nor do they seem to have a facebook page. Unfortunately this one falls into the 'hand trace only' category for raster to vector conversion. If I weren't so far behind in my work I'd be glad to draw something up, however this one would take me a minute to make into what I wanted it to be.
Re: Help with logo
Here is the Inkscape auto trace result using the image Ben provided. I agree that hand trace would produce the best result. Perhaps I misunderstood Ben when he said it would take him a minute to do it. It would take me much longer than that.
Re: Help with logo
Ponoka auto trace.dxf
ben de lappe
Re: Help with logo
Yes David, it would take me a considerable amount of time to work my magic on this one. If it only took me a minute I'd have it done. Here in the south "take me a minute" means a good while. Oppose that with "a hot minute" which means really quick. :HaHa
Re: Help with logo
ben de lappe wrote: Fri May 10, 2024 6:51 pm Yes David, it would take me a considerable amount of time to work my magic on this one. If it only took me a minute I'd have it done. Here in the south "take me a minute" means a good while. Oppose that with "a hot minute" which means really quick. :HaHa
:Like :Like :Like
Re: Help with logo
:HaHa :HaHa :HaHa
Re: Help with logo
If I were to spend the time to recreate this one, I would draw the circles/rings and letters from scratch and use the B-Spline tool in CorelDraw to hand trace the interior feature of the part. I generally do the tracing with CorelDraw, then import to Inkscape to add the rings and text. Then save as dxf and open with Design Edge to check to see how it will cut. I expect that Ben would probably do the whole thing with TMCad, or maybe CorelDraw for practice using a newer (to him) program.
As shown in the image, it would need to be a layered piece. Otherwise - some creative editing would be need to keep all the pieces together when cut. How that might be accomplished may depend on the particular end result the OP has in mind.
ben de lappe
Re: Help with logo
You are correct David, and like you said recreating this piece with the shape tool is the way to go. Drawing a shape to a specific size whether it be circle, oval, rectangle etc. is way quicker than auto tracing and straightening the result. Plus, the part I really like is that the shape will be perfect. No toying with nodes eliminating flat spots and such, jut nice and clean the way I like it. :Yay
tomloewen
Re: Help with logo
Post by tomloewen »
ben de lappe wrote: Fri May 10, 2024 4:31 pm I attempted to increase the resolution of this image to offer something a little better to work with at least but was not successful. Went online searching for a better image but the one I found on their website faired no better. Nor do they seem to have a facebook page. Unfortunately this one falls into the 'hand trace only' category for raster to vector conversion. If I weren't so far behind in my work I'd be glad to draw something up, however this one would take me a minute to make into what I wanted it to be.
Actually your version of their logo is better than mine, I'll be able to trace this out.
Tom
tomloewen
Re: Help with logo
Post by tomloewen »
adbuch wrote: Sun May 12, 2024 4:35 am If I were to spend the time to recreate this one, I would draw the circles/rings and letters from scratch and use the B-Spline tool in CorelDraw to hand trace the interior feature of the part. I generally do the tracing with CorelDraw, then import to Inkscape to add the rings and text. Then save as dxf and open with Design Edge to check to see how it will cut. I expect that Ben would probably do the whole thing with TMCad, or maybe CorelDraw for practice using a newer (to him) program.
Thanks for the info.
Tom
ben de lappe
Re: Help with logo
tomloewen wrote: Sat Jun 08, 2024 11:20 am Actually your version of their logo is better than mine, I'll be able to trace this out.
Tom
Glad the image resample helped. Judging from your previous works I've seen shared here I'd say you've got this. :Like
Re: Help with logo
Tom - good luck with your project!! We will look forward to seeing your finished result.
tomloewen
Re: Help with logo
Post by tomloewen »
adbuch wrote: Sat Jun 08, 2024 12:56 pm Tom - good luck with your project!! We will look forward to seeing your finished result.
Here it is. Thanks for the help!
It lacks the detail I like, but it'll do.
Ponoka Fish & Game logo.dxf
Re: Help with logo
Looks great Tom, should work out perfect!
Re: Help with logo
I think this one turned out great! Nice work.
