New guy from PA
New guy from PA
Not new to Plasma cutting, or metal work in general, but total newby to CNC plasma cutting.
Just setup a Langmuir Crossfire XL with Z axis and THC. Using a Primeweld Cut 60 and UPM105 machine torch. So far very pleased with the results.
Doing the drawings and CAM with Fusion 360, so far everything is working well, but I haven’t cut any thicker than 3/8” or thinner than 20ga.
Realistically, what is the thickest material that I can expect to cut with this setup? I’m sure that I’ll have a ton of questions down the road, as I acquire some experience with this setup.
Re: New guy from PA
The thickest material you can cut will depend on your particular plasma cutter. I would expect that the owner's manual for your Primeweld Cut 60 would have that information. Good luck!Popgadget wrote: Sat Apr 20, 2024 8:29 pm Not new to Plasma cutting, or metal work in general, but total newby to CNC plasma cutting.
Re: New guy from PA
It would be helpful if the Primeweld manual has a chart for you to follow pertaining to CNC plasma cutting. If not I would download a copy of the Hypertherm 65 manual and check out the cut charts there for a starting point. You will need to pay attention to the speeds selection for the thickness of each metal. Then do some test cutting to fine tune our operation, as there are differences due to torch design, THC electronics, power output of the unit. With thicker metal you may need to look at edge starting over pierce and cut.
Re: New guy from PA
The Primeweld claims up to 7/8'', but their cutting chart only goes to 3/4", so i was wondering what people have done in the real world. The Primeweld chart does give amperage, air pressure and speeds for each thickness, so far those settings have given me very clean cuts, but i havent cut anything thicker than 3/8".
Re: New guy from PA
Welcome Popgadget. You may struggle with cutting thicker than 1/2" with good results with your Primeweld unit but it doesn't sound like you will be doing a lot of thick plate cutting anyway. Glad to hear your are seeing good results so far, if you have pics of the pieces your cutting post them if you get a chance.
Re: New guy from PA
Thank you for the reply, I’ve got some 5/8” parts that I would like to cut, that why I was asking.
Here is a couple of 3/8” parts as well as a piece of 20 ga.
Re: New guy from PA
These look like very nice cuts to me. I think your settings are dialed in pretty well.
Re: New guy from PA
I would agree with David, your cuts look very good, your doing really well.
Re: New guy from PA
Thank you. As I said, I’m new to CNC plasma cutting, but not new to metal working. I got my first OA torch over 60 years ago.
My biggest challenge is understanding Fusion.
Re: New guy from PA
If you are using Fusion 360 for your cad/cam and cut paths, then I would say you have a pretty good basic understanding.Popgadget wrote: Tue Apr 23, 2024 9:59 pm Thank you. As I said, I’m new to CNC plasma cutting, but not new to metal working. I got my first OA torch over 60 years ago.
Langmuir has some pretty good tutorials - in case you haven't seen them.
Re: New guy from PA
Yes, I am making the drawings in Fusion, and then using the CAM functions for the cut paths and generating the G code.
Its more of a struggle with the sketch portion, as its all new to me.
I am reasonably fluent in Corel Draw, but am trying to stay in Fusion rather than importing DXF from Corel.
Re: New guy from PA
It's great that your fluent in Corel Draw. I find Fusion very cumbersome for artistic designs but amazing for mechanical designs so I use both and do all my artistic stuff in Corel and mechanical in Fusion. Look forward to seeing more of your plasma work.
