PrimeWeld Cut60 Settings Chart
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
AdamE
Post by AdamE »
Simple chart to help with STEEL cut settings not listed in the PrimeWeld manual. These may not be the optimal settings for you, but will be a great place to start to further dial in to perfection. .PDF file attached
PrimeWeld Cut60 Amp vs IPM.pdf
kicktillmonday
Re: PrimeWeld Cut60 Settings Chart
Post by kicktillmonday »
Great looking chart, I will give it a try and see if i have better luck, I was cutting everything at WOT.
DIY 4x8 table
Powermax 65
AdamE
Post by AdamE »
kicktillmonday wrote: Mon Feb 05, 2024 12:17 pm Great looking chart, I will give it a try and see if i have better luck, I was cutting everything at WOT.
A good visual always helped me so i figure i cant be the only one, thanks. The values are (for the most part) interpolated from the settings chart primeweld provides in their manual. Likely wont be perfect but otta be in the ball park.
Awesome
Post by Awesome »
Thank you. This is very helpful. I'm using a Duramax torch adapter for the Primeweld Cut60, so I was using the Hypertherm settings and wasn't getting good cuts. I'll try this. Looks like my settings were too fast.
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
