The most new guy post of the year
KNPV-PSD
Post by KNPV-PSD »
I just inherited a PM85 and cannot figure out the air quick connect size and style....all my stuff is automotive QC and they do not work. Checked the online manual and parts list and no help there...
Anyone know?
ROKCRLER
Re: The most new guy post of the year
Post by ROKCRLER »
Change the fitting to the size you use.
Machines come without air fittings (at least all of mine did)
4x8 Dynatorch
PM85
~Mo~
KNPV-PSD
Post by KNPV-PSD »
Good call thanks.
The manual call out using a 3/8” hose for supply. Is there any restriction issue with using a 1/4” automotive fitting?
ROKCRLER
Post by ROKCRLER »
I'm running 1/4" from compressor to motor guard filter to plasma, but they're all within 24" of each other.
I use the coil hose and use it to blow-off the table and area when not cutting.
Put a guage at the back of the plasma and ensure you're getting and maintaining 100+ psi when cutting.
4x8 Dynatorch
PM85
~Mo~
KNPV-PSD
Post by KNPV-PSD »
Thanks for the help!
ROKCRLER
Post by ROKCRLER »
Anytime, let us know how how it goes
4x8 Dynatorch
PM85
~Mo~
You may find 1/4 to be restrictive. In Mo's case his run of line is very short so it works out but I would suggest stick with 3/8" to ensure you have no flow rate issues. Restricted air flow will cause a lot of headaches. As Mo suggested a gauge on the back of the Hypertherm unit so you can monitor incoming pressure is very helpful.
