Plasma Cutter Power Sources
Brig
Post by Brig »
Read several posts on here but am still confused. Might be because I'm not an electrically-inclined guy yet, so figured I'd ask a couple questions for clarity.
I recently bought my first house and am slowly converting the barn/garage into a small workshop. The house had been abandoned for a couple years before it was renovated and flipped to myself, and during that time scavengers had stolen most of the electrical components from the outbuildings. Recently I dug and ran wire from the house to the barn and installed a 50amp box. I am yet to wire the outlets or lights.
I got inspired to look into plasma cutting shortly after I had run the wire. I understand that cutters eat a lot of power, so am I correct in assuming that a 50 amp box would be insufficient to run a plasma cutter?
I figure I could run one off a generator, as I intend to get one for the house anyway and had a generator hookup installed at the same time I ran the wire. I've read some posts about plasma cutters and generators not running smoothly, together, however, so I'm curious what size I would need to allow most plasma cutters to run smoothly?
I know some of these questions depend on the size and type of cutter, but as I don't have one yet I can shop with the considerations in mind.
robertspark
Re: Plasma Cutter Power Sources
Post by robertspark »
try not to cross post
https://www.plasmaspider.com/viewtopic. ... 15#p231508
50A at what voltage and how many phases
what do you want to cut?
how much do you intend to cut and what is your intended duty cycle
there is the 30xp, 45xp
or
https://www.everlastgenerators.com/cata ... sma-cutter
are an option as well as others
hypertherm.tend to have the best manuals for operators and servicing
You will also need to run a compressor for the plasma cutter, I ran a 100 amp breaker from the main input to my shop. It handles the compressor and the plasma fine, I have a 65 amp hyperther.
