Adding NPN proximity switches to table i/o board?
Tristar500
Post by Tristar500 »
My machine came with no homing /limit switches.
I'd like to add this to the machine.
I could us a relay to accomplish this but wondering if I can just use the 12-36VDC signal coming from the proximity sensor?
Thanks in advance!
50X50 plasma w/ pneumatic drill- own design
Mach3,4 SheetCam, CorelDRAW 2020
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60 Plasma
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
He who is without oil shall throw the first rod
Compressions 8.7:1
sonbakler
Re: Adding NPN proximity switches to table i/o board?
Post by sonbakler »
I dont see why not but not sure but Tom from C&CNC is often here answering questions, maybe he will chime in.
Post by djreiswig »
There's a diagram in the candcnc manual that shows how to use proximity sensors for homes. You have to use an external power source if I remember correctly.
Post by djreiswig »
I added proximity sensors to my DIY table and here is some info that may help. They are mostly the same Electronics just different mounting for the 2 types.
viewtopic.php?f=122&t=36054
Return to “CandCNC Forum”
