Plasma contoller freezes
josiah00iam
Post by josiah00iam »
Hey guys!
I'm running a Messer plasma table with dual HPR260HD power packs. I bought it used and have fixed quite a few issues, but one issue I'm left with is that it the controller freezes randomly. And then I have to kill the power and restart to get back rolling. It uses the windows XP for a PC.
Has anyone ever heard of that problem?
-Josiah
Re: Plasma contoller freezes
Can you pinpoint anything that happens just prior to the lockup? Torch fires? Another piece of equipment in the shop fires up?
Does this use a C&CNC controller?
josiah00iam
I had an uncle in the shop today and he suggested I plug in a mouse to see if it moves, shure shittin, everything works but the touch screen!!
So at least I can use a mouse to keep going instead of shutting down the machine and restarting.
Any one know how to fix a touch screen ?
josiah00iam
Yes it does have a CNC controller
Good find, that makes it a little better. Check your touchscreen's AC power plug that it has the ground prong on it and be sure the outlet it's plugged into has a functioning ground. If it's plugged in with an extension cord be sure the extension cord has a functioning ground prong on it.
josiah00iam
As far as I can see I have good ground connections all around ...
SegoMan DeSigns
Post by SegoMan DeSigns »
Are you using a common ground point along with a ground rod to dissipate static charges?
https://www.plasmaspider.com/viewtopic.php?t=25456
josiah00iam
I do have a grounding rod but I havent tested it .... I just hammered it 8 ft down and connected it to the table
Return to “CandCNC Forum”
