Machine Torch Marker Attachment
SRdesign
Post by SRdesign »
Would anyone happen to know the thread and pitch of the threads on the end of the Duramax machine torch? Specifically the threads that the retaining cap screws onto. Any help is appreciated. Thank you
My 4x8 Build
DIY 4x8
C&CNC Bladerunner G5
Hypertherm PM85
Francisco
Re: Hypertherm Duramax torch thread
Post by Francisco »
I don't have my thread gauges handy but, measured with calipers, it seems to be 3/4-16NF. YMMV.
SRdesign
Post by SRdesign »
Awesome. Thanks man I really appreciate it
My 4x8 Build
DIY 4x8
Hypertherm PM85
Ok, you have peaked my curiosity, sounds like your hatching a plan for something cool and inventive to go on the end of the torch.....
SRdesign
Post by SRdesign »
weldguy wrote: Thu Aug 17, 2023 10:30 am Ok, you have peaked my curiosity, sounds like your hatching a plan for something cool and inventive to go on the end of the torch.....
Haha, yes at this point it’s just a plan. But I’m tinkering around with shortening some fineliner pens. The plan is to make a spring loaded marker that you don’t have to offset or anything like that, it will just screw onto the torch. Possibly going to try to include an ohmic sensing clip for those that don’t have the ability to set a z zero…. It will leave a small ink blob where it starts but I’m going to try to figure that out once I get the non ohmic sensing marker done first.
My 4x8 Build
DIY 4x8
Hypertherm PM85
SRdesign wrote: Thu Aug 17, 2023 5:30 pm
I did something similar for a torch pointer. The one I did is 3D printed and fits inside the existing torch cap in place of the electrode/nozzle.
I expect something similar could be done using the existing cap with a pen insert in place of the pointer.
The challenge would be to come up with a short pen cartridge. I've never tried cutting off a sharpie marker, but perhaps that would work. Not sure how long the ink would last. It would probably be easier to cut off/shorten ball point pen refills.
https://www.ebay.com/itm/125453655657?h ... R9zUquLAYg
Maybe something like this for the cartridge.
You could also probably 3D print a "custom cap", maybe a bit longer to better accommodate the pen/spring. Let me know if you have something in mind and I'd be happy to model it up for you.
SRdesign
Post by SRdesign »
I like that indicator. I’ve ordered some “fineliner” pens. They’re .8mm, very similar to the sharpie ultra fine point pen, but not as long of a “capped section” if that makes sense (the portion of the pen that would be under the cap). I’m going to start by taking that apart and see how small I can cut it down without getting too far into the ink. The plan is to 3d print a bottom piece that the pen will drop into to the depth of where the cap sits, then print a top piece that a very light spring and two bearings will fit into. The top piece will screw onto the torch threads. We’ll see. Could be a total bust. Could work. The pens get here tomorrow so I’ll hack one up and know how large or small this will be then.
My 4x8 Build
DIY 4x8
Hypertherm PM85
SRdesign
Post by SRdesign »
The problem with a traditional sharpie is that it has a slight taper to it. These pens are a straight tube. No taper. So I’m thinking they will slide up and down in the bearings.
My 4x8 Build
DIY 4x8
Hypertherm PM85
Post by djreiswig »
They make short pens for use in plotters. Maybe something like that would work without much modification.
SRdesign
Post by SRdesign »
Awesome. Thank you. I will check that out
My 4x8 Build
DIY 4x8
Hypertherm PM85
SRdesign
Post by SRdesign »
Finally came up with something. Requires no offset in sheetcam. I just use the contour operation. It’s a pretty simple installation: remove my consumables, slide it onto the torch body, tighten the machine screw. It does add 1.5” of additional Z length, but I have plenty of Z travel so it doesn’t affect me. If you’re interested in one you can pick one up here:
https://overthetopfab.etsy.com/listing/1598577295
My 4x8 Build
DIY 4x8
Hypertherm PM85
that is slick happy you figured it out :Like
SRdesign
Post by SRdesign »
acourtjester wrote: Sun Oct 29, 2023 10:41 am that is slick happy you figured it out :Like
Thank you sir.
My 4x8 Build
DIY 4x8
Hypertherm PM85
CarterKraft
Re: Machine Torch Marker Attachment
Post by CarterKraft »
Excellent results.
How did you handle the "blob" I was wondering about a "ramp" pierce.
SRdesign
Post by SRdesign »
I don’t use a plasma operation in sheetcam when I use the marker attachment. I use the router operation and just set my zero with the marker compressed about a 1/4”. Plus these markers do not have a soft tip. So it does good as far as not leaving a blob. I plan on making an ohmic sensing version of this attachment so I can just use the same plasma operation that I will use when I’m cutting. But I haven’t drawn it up yet.
My 4x8 Build
DIY 4x8
Hypertherm PM85
CarterKraft
Thanks for those tips.
Willdamnit
Post by Willdamnit »
I have the easy scriber works well for marking bend lines and holes,
I too use the plate marker in sheetcam for this process
SRdesign
Post by SRdesign »
The easyscriber is a great tool. Especially for dialing in your table and making sure it is 100% square and accurate. You can only get so fine of a measurement with a marker. I mostly wanted this attachment for testing drawings before I cut the metal. The reason I wanted to use a marker is because I can just wipe it clean with acetone if something is not right, instead of scratching my metal.
My 4x8 Build
DIY 4x8
Hypertherm PM85
SRdesign
Post by SRdesign »
The ohmic sensing version has been made. It makes marking so easy now. I just attach, then run the same nc file as if I were cutting, then remove, then run the same nc file again with consumables installed.
My 4x8 Build
DIY 4x8
Hypertherm PM85
SRdesign wrote: Thu Dec 28, 2023 8:47 am The easyscriber is a great tool. Especially for dialing in your table and making sure it is 100% square and accurate. You can only get so fine of a measurement with a marker. I mostly wanted this attachment for testing drawings before I cut the metal. The reason I wanted to use a marker is because I can just wipe it clean with acetone if something is not right, instead of scratching my metal.
:Like :Like :Like
SRdesign wrote: Sun May 26, 2024 7:54 pm The ohmic sensing version has been made. It makes marking so easy now. I just attach, then run the same nc file as if I were cutting, then remove, then run the same nc file again with consumables installed.
Unfortunately I am running a hand torch on my Plasmacam table, so not enough room to install your marker - otherwise I would buy one. It looks like a great attachment to have and the price is very reasonable.
SRdesign
Post by SRdesign »
Thank you for the kind words David.
My 4x8 Build
DIY 4x8
Hypertherm PM85
