Hello all.
I'm from england uk ..and have been a welder for around 25 to 30 years and after having to cut out the last two projects 3mm sheet with an angle grinder i decided a plasma build was long over due i have around 80 percent of build in parts and was trawling the web when i came across the forum.
Thanks for having us.
hello hello
Re: hello hello
Welcome! Many here including myself would be interested to see your build if you have the chance to posts pics. Sure would be nice to retire the angle grinder for intricate cutting operations!
Re: hello hello
Thanks plasma,Will do.
- Joe Jones
Re: hello hello
Welcome to the madness! I also would like to see how you set up your table, and the type of things you make with it.
Re: hello hello
Welcome aboard! I will look forward to following your diy table build.
Re: hello hello
Thanks all,It will be a 4x2 ft-ish, It will help me build a bigger table at a later date when i upgrade the shed..Joe Jones wrote: Mon Aug 14, 2023 8:40 pm I also would like to see how you set up your table, and the type of things you make with it.
After my last project (link below) and the one before that i decided I am doing no more cutting with a grinder.
The forum has already got me questioning the electronics i allready have...cheap mach3 board,mach 3 etc..im now looking at the proma myplasm set up.
i will start a thread soon.thanks
Re: hello hello
Welding Shed - thanks for the video! That's a really nice looking wood stove you built. Back in the day I had a wood burning stove made from an old oil drum. It was right here in my office, which in those days was my entire workshop of 300 square feet. Keep us posted on your diy build. I actually did a small diy build a few years ago. It was intended to be a cnc router with cnc plasma cutting capability. I was using an Arduino/grbl combo and it actually worked pretty well. You can read more about it here.
https://desert-hybrids.com/id57.html It was intended as a small machine for the home hobbyist.
Good luck with your own diy project.
Re: hello hello
Thanks david i will take a look.
