Sheetcam touch off post - Touch off first cut only
Patriotcustoms
Post by Patriotcustoms »
Hi, I have a candcnc set up with floating head. post in sheet cam is touching off for every cut and is working fine as always. Im cutting a job that each plate is 21" x 4.5" with with 95 holes and i only want to touch off on the first hole as the cycle time is way too long touching off on every hole. the plate is small and doesn't move so touch off on every hole is not necessary. is there a way to do this. Thanks in advance.
final cut 1 up.dxf
Re: sheetcam touch off post
Perhaps turn off your thc and set you cut height manually. Unless you are cutting really thin material subject to excessive warping, then you should be fine. Otherwise you may need to modify your post processor to accommodate.
Post by djreiswig »
The CandCNC post should have a refDist variable. If you set it to a really big number it shouldn't reference every time. On my system I think it is changed in the post options.
djreiswig wrote: Sat Apr 16, 2022 7:24 pm The CandCNC post should have a refDist variable. If you set it to a really big number it shouldn't reference every time. On my system I think it is changed in the post options.
:Like :Like :Like
Patriotcustoms
Yes, exactly what I needed refDist. I was able to dial in that number to get the touch off sequence perfect. Thank you so much, I have hundreds of these to cut and this will save me a lot of hrs.
Post by djreiswig »
Glad it worked for you. Happy cutting.
Jim@Western Welding
Re: Sheetcam touch off post - Touch off first cut only
Post by Jim@Western Welding »
The reference distance is also what I was needing and I got it set like I want but it fires the torch at 2” (rapid travel) instead of the pierce height. Any advice on this?
Return to “SheetCam”
