SheetCAM Mach3 Plasma Cutter G-Code Issue.
sreza26
Post by sreza26 »
Dear Valued Member's, I am New in SheetCAM and this forum. Can you please help me to resolve my problem.
I'm having an Issue with my Newly Started CNC Plasma Cutter Machine projects. I have Installed SheetCAM TNG 6.0.28 for My Mach3 Non THC Plasma Cutting machine. I imported DXF file which is OK. The DXF works fine on LazyCAM.
But its generating Incomplete G-Code On SheetCAM.
N0010 (Filename: Reza-Faruk_01_03-23_1.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 01/03/2023)
N0040 G21 (Units: Metric)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: Reza-Faruk)
N0090 M05 M30
When i try to simulate the Job it finished with Error...
Post processing...
Part:Reza-Faruk
Outside Offset, Layer_1, T1: Plasma_Mach3_LGK100
Warning: WARNING: Feed rate is zero
Post processing completed with 1 warnings
I think, I followed every Configuration Steps. I am using "Mach3 plasma Post processor"
Re: SheetCAM Mach3 Plasma Cutter G-Code Issue.
Do you have a feed rate in the tool that you are using, Your sample G-code shows a F of 1 and no axis for the move command.
In Mach 3 under the MDI page in the input box type G1 X 3 f 50 enter key that should move the X 3 inches/mm (your choice of measurement) at about a fair speed.
Les Newell
Post by Les Newell »
Check the feed rates in your cut operations. Additionally check the feed rate and plunge rate in your tool definition.
sreza26
Post by sreza26 »
acourtjester wrote: Wed Mar 01, 2023 1:02 pm Do you have a feed rate in the tool that you are using, Your sample G-code shows a F of 1 and no axis for the move command.
Tnx for Replaying,
I am using a Offline Mach3 Software for simulation and "G1 X 3 f 50" Command working Fine under MDI. I just want to Generated a G-Code from SheetCAM and Run it on a live machine. G-Code Generated on LazyCAM Just working Fine on Machine for me.
My Tools configuration is as bellow..
My Operation configuration is as bellow..
Tnx in Advance
sreza26
Post by sreza26 »
Les Newell wrote: Wed Mar 01, 2023 1:31 pm Check the feed rates in your cut operations. Additionally check the feed rate and plunge rate in your tool definition.
Please see my above post for details..
Post by djreiswig »
Is your SheetCam licensed? I think I've seen this come up before and it was a licensing issue. I'd either post this on the SheetCam forum or email Les at SheetCam.
sreza26
Post by sreza26 »
djreiswig wrote: Thu Mar 02, 2023 7:03 am Is your SheetCam licensed? I think I've seen this come up before and it was a licensing issue. I'd either post this on the SheetCam forum or email Les at SheetCam.
Tnx For Replaying.
Is it a license Issue ?! I have Downloaded the Copy of SheetCAM Randomly sourced from internet...
Tnx in Advance
Post by djreiswig »
Go to SheetCam.com & download the latest version.
Les Newell
In SheetCam go to Help->about. If you send me the license id in an email or PM I'll check it for you.
sreza26
Post by sreza26 »
djreiswig wrote: Thu Mar 02, 2023 10:11 am Go to SheetCam.com & download the latest version.
Tnx @All
My issue is solved. It was License Issue. I have downloaded the Trial Version and it works Fine Now
Return to “SheetCam”
