Having size issues, size is double
Kajeti
Post by Kajeti »
hi recently i ve been working with a guy who gave me job offering for a side job to run his table. i can get the table to everything i need the only issue is from the computer to the table the sizes are off.. example if i make a 1x1 square it cuts it at 2x2 so on an so forth. i dont wanna spend all my time halving my measurements for it to cut the pieces out.. using myplasma cnc and the mini cad for my drawings and even tried to import stuff from inkscape still doubles the size.. changed the sizes of the files % and still nothing works is it on the computer end or what? his setup is a hypertherm and sparta robotics
Plasma-art
Re: First post. Having size issues
Post by Plasma-art »
Welcome on the forum.
If you jog the table over 1 inch does it move 1 or 2 inch?
First thing that comes to mind is the steps per inch are calibrated incorrectly.
Kajeti
Post by Kajeti »
Plasma-art wrote: Sun Jan 08, 2023 4:57 pm Welcome on the forum.
That i do not know i ll have to get back with you at the end of the week i farm as my main job and do this as a side gig on downtime. Say if was calibrated wrong how would i go about fixing it. I ve never ran one of these i m a youtube learner and know how program things for games and program tractors. Is it a basic set one a to point be or something different?
If it is running Mach 3 to recalibrate is very easy, there are many YouTube videos on recalibrating a CNC table. Call the guy and ask which software is used to run the table is the first step. There should be indicators on the screen as to positions and as Plasma-art said you move one axis and look at the indicator to see how much it moved. And measure what it actually moved and you have an answer about if it need to recalibrated.
It sounds like you simply need to adjust the turns ratios for you motors.
Kajeti
Post by Kajeti »
adbuch wrote: Sun Jan 08, 2023 8:42 pm It sounds like you simply need to adjust the turns ratios for you motors.
acourtjester wrote: Sun Jan 08, 2023 7:38 pm If it is running Mach 3 to recalibrate is very easy, there are many YouTube videos on recalibrating a CNC table. Call the guy and ask which software is used to run the table is the first step. There should be indicators on the screen as to positions and as Plasma-art said you move one axis and look at the indicator to see how much it moved. And measure what it actually moved and you have an answer about if it need to recalibrated.
okay thanks! i ll gives those a try
Kajeti wrote: Sun Jan 08, 2023 9:00 pm
:Like :Like :Like
Let us know now you make out.
Kajeti
Re: Having size issues, size is double
Post by Kajeti »
So there is no mach program and where can i get one?
Plasma-art
What software are you running exactly?
If you know where the step per number is stored in the program you can do a simple calculation to correct them. This formula can be used for inch or MM. You mark the rail and tell the axis to move so far then measure it, that is the actual travel number. The current is what is noted in the software as the original steps per value. And the Expected is the measured distance. Do the calculations and change/save the number in the software and repeat the activity about 3 to 4 times until the expected and actual travel distance is the same (equal). It helps if you extend the travel distance to a greater distance each new time to get a more accurate number. :Like
Kajeti
Post by Kajeti »
hes running mycnc plasma by spark robotics finally just called them and they had his info all saved and told me what to do.. what happen was instead of 1/32 it was set on 1/16 so it was doubling the size
Kajeti
Post by Kajeti »
Now my next problem is i have all these tap files that are g codes that were saved by sheetcam but wont work with his current setup how do i go about saving a g code in sheet cam as a dxf file
Kajeti wrote: Sun Jan 15, 2023 6:19 pm hes running mycnc plasma by spark robotics finally just called them and they had his info all saved and told me what to do.. what happen was instead of 1/32 it was set on 1/16 so it was doubling the size
Thanks for the update! Glad to hear you've got it sorted out.
Kajeti wrote: Sun Jan 15, 2023 6:20 pm Now my next problem is i have all these tap files that are g codes that were saved by sheetcam but wont work with his current setup how do i go about saving a g code in sheet cam as a dxf file
Are you looking to convert tap files to dxf?
Here is some information that may help you.
viewtopic.php?t=18226
Kajeti
Post by Kajeti »
adbuch wrote: Sun Jan 15, 2023 6:24 pm Here is some information that may help you.
Thats what i m aiming for but i do not know how to reverse it or what the offset was
Kajeti wrote: Sun Jan 15, 2023 8:38 pm
I think the offset would be 1/2 the kerf width used when the cut file was created. So maybe 0.025" to 0.040" (1/2 kerf width) depending on the original cutter/consumables used. Do you have an example tap file for us to play with? I'm not sure if this forum allows the .tap format for attachments. Let me see.
Here is a file I created with Aspire and saved the toolpath as a .tap file. Then I compressed it to save as a .zip file.
TAP FILE.zip
When opened the code will look like this.
So if you would like to take one of your tap files and compress using bitzipper or equivalent and post the zip file,
then we can take a look.
