PCM to DXF help
waylon
PCM to DXF help
Post by waylon »
Is there anyone can convert this PCM into a DXF or SVG. Thanks for any help
viewtopic.php?f=6&t=30406&p=184078&hili ... or#p184078
Re: PCM to DXF help
waylon wrote: Sun Jul 10, 2022 8:37 pm Is there anyone can convert this PCM into a DXF or SVG. Thanks for any help
radiator relocate kit ps.dxf
waylon
Re: PCM to DXF help
Post by waylon »
Very nice thank you so much !!!
Re: PCM to DXF help
waylon wrote: Sun Jul 10, 2022 10:33 pm Very nice thank you so much !!!
:Like :Like :Like
maghunter120
Re: PCM to DXF help
Post by maghunter120 »
I have several pcm files that i have collected over the years. Can someone convert them to dxf? Hopefully someone one can use them as well. Thanks.
maghunter120
Re: PCM to DXF help
Two more.
Re: PCM to DXF help
I spent some time cleaning some of these up. Some were cut paths needing converting to drawings, and others has many overlaps, etc. needing editing.
They should all be fine now with no intersections detected.
unicorn.dxf
Trout 2 x4.dxf
skullgasmask2.dxf
patriotic deer.dxf
LoveArrow.dxf
FFA Baraboo Logo edit 1.dxf
Australian Shepard.dxf
Circle.dxf
Clarksdale Bikes pcm.dxf
COFFEE.dxf
Re: PCM to DXF help
usaconfederatetexas.dxf
Re: PCM to DXF help
patriotic deer.dxf
maghunter120
Re: PCM to DXF help
adbuch wrote: Sat Jan 07, 2023 9:08 pm I spent some time cleaning some of these up. Some were cut paths needing converting to drawings, and others has many overlaps, etc. needing editing.
unicorn.dxfTrout 2 x4.dxfskullgasmask2.dxfpatriotic deer.dxfLoveArrow.dxfFFA Baraboo Logo edit 1.dxfAustralian Shepard.dxfCircle.dxfClarksdale Bikes pcm.dxfCOFFEE.dxf
Thank you very much. Like I said, I've had these files for some time and didn't have a way to open or modify them.
Re: PCM to DXF help
COFFEE.dxf
Re: PCM to DXF help
LoveArrow.dxf
patriotic deer.dxf
skullgasmask2.dxf
Trout 2 x4.dxf
Re: PCM to DXF help
unicorn.dxf
wisconsin.dxf
Re: PCM to DXF help
maghunter120 wrote: Sat Jan 07, 2023 9:45 pm
Your are quite welcome! No problem at all, and happy to help.
