Removing powder coat
The most amazing powder coat remover lifts it in minutes.
Re: Removing powder coat
Wow! I was just thinking the other night that I needed something to remove old powder, going to burn out my compressor trying to sandblast it off. This is a priceless tip and VERY much appreciated. I was just going to start searching for something, will order some of this. Thank you!
- Joe Jones
It occurs to me that this stuff MIGHT be awesome for removing GRAFFITI as well!
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Looks like very limited locations to buy, no eBay or Amazon
- Joe Jones
I think I’m going to buy a can anyway and try it on graffiti just to see if it does what I think it will do. If it does I’ll buy a couple of cases of it and carry it around in my truck with me and go on my own personal war against graffiti!
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
I had some difficulty finding it also. Seems it goes by a couple of different names. I ended up buying some from Grainger and it was called Chisel Gasket Remover but when it delivered the can said SF 790 just like OTHills. Haven't tried it yet but def look at Grainger and don't be fooled by the nameacourtjester wrote: Thu May 12, 2022 7:40 pm Looks like very limited locations to buy, no eBay or Amazon
thanks
I wish I had known about that several years ago. The powder coater for to mask off part of the brake pedal assembly for the 1940 Ford hot rod I was building and I had to grind it off for clearance. I probably spent over an hour messing around with it. The only thing I would say is that one needs to very thoroughly mask off any areas where you don't want the powder coat removed so it doesn't get on a good surface by mistake.OTHill wrote: Fri Mar 04, 2022 1:07 pm The most amazing powder coat remover lifts it in minutes.16464171841881164959584245791315.jpg
But a great product, and thanks for sharing that with us.
Ok finally got an opportunity to try this Loctite SF 790 for stripping powder coat. WOW!!! All i can say is WOW!!! I sprayed a little on and within seconds the powder coat blistered and wiped right off!! Would have taken me 30 minutes to sandblast this part but this stuff stripped in 2 minutes. Highly recommend
I still sandblasted the part after just to get a fresh clean surface for the new powder to bite onto but this stuff saved me so much time and effort. Thanks to OTHill for the tip
Thanks for verification feedback always great when a product works as stated.
- Joe Jones
I have not experimented with removing powder coating. Would MEK work? What about Acetone? Has anyone tried Super Strength OVEN CLEANER? I have used that to remove graffiti from walls. The results depend heavily on what kind of spray paint was used. Some falls off, while other paints laugh at oven cleaner. The SF 790 is a powerful paint stripper, so maybe that is why it can remove powder coat so well. I would have the irresistible urge to spray it onto an old car hood, just to see what it would do to the paint. Maybe jealous girlfriends already know about this.
Every job has a tool.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
After using this stuff Joe I wouldn't waste my time on anything else. I can't remember the last time i tried something and it worked far beyond my expectations, typically it's a bitter disappointment so this was a real treat. Honestly it is worth having on your shelf and I just ordered mine from Grainger online after reading the OTHill's original post, been sitting here for months and just had an opportunity to try it. Thrilled! Thanks for the tip OTHillJoe Jones wrote: Mon Jul 25, 2022 5:16 pm I have not experimented with removing powder coating. Would MEK work? What about Acetone? Has anyone tried Super Strength OVEN CLEANER? I have used that to remove graffiti from walls. The results depend heavily on what kind of spray paint was used. Some falls off, while other paints laugh at oven cleaner. The SF 790 is a powerful paint stripper, so maybe that is why it can remove powder coat so well. I would have the irresistible urge to spray it onto an old car hood, just to see what it would do to the paint. Maybe jealous girlfriends already know about this.Every job has a tool.
weldguy wrote: Tue Jul 26, 2022 4:32 pm
After using this stuff Joe I wouldn't waste my time on anything else. I can't remember the last time i tried something and it worked far beyond my expectations, typically it's a bitter disappointment so this was a real treat. Honestly it is worth having on your shelf and I just ordered mine from Grainger online after reading the OTHill's original post, been sitting here for months and just had an opportunity to try it. Thrilled! Thanks for the tip OTHill![]()
Wow powder foamin action. Can I buy it from Walmart or Amazon?OTHill wrote: Fri Mar 04, 2022 1:07 pm The most amazing powder coat remover lifts it in minutes.16464171841881164959584245791315.jpg
Here are several sources for this product. Aircraft paint stripper may work also.Toni hausfeld wrote: Sun Sep 04, 2022 1:52 amWow powder foamin action. Can I buy it from Walmart or Amazon?OTHill wrote: Fri Mar 04, 2022 1:07 pm The most amazing powder coat remover lifts it in minutes.16464171841881164959584245791315.jpg
https://www.zoro.com/loctite-chisel-gas ... lsrc=aw.ds
https://www.rshughes.com/p/Loctite-SF-7 ... 340_79040/
https://www.emisupply.com/catalog/locti ... -3275.html
Your best bet is to get someone with a business license or if you have one to order stripper from somewhere like Benco and their B17 stripper or Express Chems and their Rim Strip. The problem with off the shelf strippers is in March of 2019 the EPA banned the use of Methylene Chloride based strippers to the public so you have to send a w4 to one of the sellers of these type of strippers. Another route is the so-called Green powder coat strippers the only problem with them is they cost at least double the MC based strippers and they have to be heated to be effective and that's another expense. Over the counter strippers just dont have enough umph to remove powder. I hope this helps you
Thanks for that information!dbug10 wrote: Sat Oct 22, 2022 5:06 pm Your best bet is to get someone with a business license or if you have one to order stripper from somewhere like Benco and their B17 stripper or Express Chems and their Rim Strip. The problem with off the shelf strippers is in March of 2019 the EPA banned the use of Methylene Chloride based strippers to the public so you have to send a w4 to one of the sellers of these type of strippers. Another route is the so-called Green powder coat strippers the only problem with them is they cost at least double the MC based strippers and they have to be heated to be effective and that's another expense. Over the counter strippers just dont have enough umph to remove powder. I hope this helps you
Thanks for sharing this info!
I ordered 2 cans (SF 790) from emisupply.com (I get my Walter flap disc from them all the time)
for $24.28 each but UPS charges $25.89 for shipping!
If it works I think it will be worth it on a couple custom signs that didn't come out right!
I think you will be happy Jeff. From what I have learned using it is, wear a mask, it doesn't smell but it can't be good for you regardless! Also shake the can very well before using for best results, and if the base metal was sandblasted prior to powder it will need to sit wet longer for the powdercoat to lift. If the powder is on a bare un-etched metal surface it will wrinkle in seconds but a good finish needs to sit longer.J-SIG wrote: Mon Jan 16, 2023 11:39 am Thanks for sharing this info!
weldguy wrote: Mon Jan 16, 2023 11:52 amI think you will be happy Jeff. From what I have learned using it is, wear a mask, it doesn't smell but it can't be good for you regardless! Also shake the can very well before using for best results, and if the base metal was sandblasted prior to powder it will need to sit wet longer for the powdercoat to lift. If the powder is on a bare un-etched metal surface it will wrinkle in seconds but a good finish needs to sit longer.J-SIG wrote: Mon Jan 16, 2023 11:39 am Thanks for sharing this info!
Looking forward to trying it!
