Cutmaster 60i THC - Raw Voltage or Divided Volatge
Langmuir Crossfire, Crossfire Pro, Crossfire XR plasma table discussion forum
MUFOSTAA
Post by MUFOSTAA »
Anyone have any experience running a Z-axis with torch height controller on a thermal dynamics machine? I don’t have an interface card and was wanting to run off of direct voltage instead of divided, but I have read there are some issues with constant voltage for arc start purposes preventing the “OK to start” relay. Any thoughts?? Personal experience? Thanks!
MUFOSTAA
Re: Cutmaster 60i THC
Post by MUFOSTAA »
Also, should I cross post this to the Thermal Dynamics thread? Not sure of rules for cross posting. Thanks!
You need to match your arc voltage to the requirement of your thc. In most cases, this requires adding a voltage divider (two resistors) to reduce the raw arc voltage to a level compatible with the thc.
MUFOSTAA
Post by MUFOSTAA »
The THC on the Langmuir Systems has a 50:1 divided option, or a raw voltage option. I’m not much of an electrician, so raw voltage seems more within my capabilities IF it will work
MUFOSTAA wrote: Wed Jul 20, 2022 7:02 pm The THC on the Langmuir Systems has a 50:1 divided option, or a raw voltage option. I’m not much of an electrician, so raw voltage seems more within my capabilities IF it will work
I would recommend reaching out to Langmuir tech support for a definitive answer to your question.
https://www.langmuirsystems.com/support
(833) 526-4797
I would wire it up for RAW voltage and go with it if your THC will accept it. Quick, easy, cheap and in some cases works better than divided setups. Plasma tables ran RAW voltage for years before divided voltage was a mainstream thing. I doubt you will have any issues but post back and let us know.
Return to “Langmuir Crossfire Forum”
