DXF to Gcode with mach3 plasma postprocessor on sheetcam
Kir
Post by Kir »
Hi There
I am new to booth to this forum and and plasma just build my new DIY table with mach3 wanted to see if sheetcam can generate the right file for my table and need help with changing this two files to "mach3 plasma" and "Mach3 plasma No Z" post before buying sheetcam license can anyone help?
thanks
Re: DXF to Gcode with mach3 plasma postprocessor on sheetcam
Post by tnbndr »
You can download a free trial version of SheetCam.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
The tree loaded into SheetCam fine no errors showing up, there are many Post Processors in SheetCam for Mach 3 for you to pick from
Those are both nice clean files, and I particularly like the second one - it has a real 3D feel to it. I agree with both Tom and Dennis that with the correct post processor for Sheetcam to match your system, you should have great luck cutting these. I know that the Sheetcam trial version has a code line limit, but you could try it out on something simple just as proof of concept before upgrading to the unlimited version.
Good luck!
