designing 3 dimensional art signs without studs
ArtG223
Post by ArtG223 »
Hi im looking for a way to layer a sign without having to use studs kinda like using the tab and slot feature from solid works. The idea is to design the first layer with tabs on the edges to bend 90 degrees the tricky part is the back plate how to locate the slots to were the first layer lines up perfect. I was told inkscape would work but I doubt it I cant figure it out. So the question is is there a program that can make this happen? I included some pics so you guys can get the idea. Thanks!
Re: designing 3 dimensional art signs without studs
Post by djreiswig »
Just draw some tabs and test cut them to see how much offset you need to allow for the bends. Then overlay the top layer on the bottom layer and offset a slot that distance from the edge of the top layer where the tab is. If you want to twist the tabs to hold the layers together, you will have to have the upper portion of the tab larger than the slot . Shouldn't be too difficult once you figure out the clearances.
If you place masking tape in the locations of the tabs and mark around them. Next drill mounting holes in the back part inside of the marks. then reposition the front part in its location and mark the holes from the back side to be drilled for the screws. I used these fasteners they install like Pop Rivets.
https://www.ebay.com/itm/184082073183?h ... Sw3d9d9VhG
Some of those look like front tab sticks through the back and twist the tabs that protrude through the back side to hold them in place. The tape making will also work for the locations of the penetration.
ArtG223
Post by ArtG223 »
would you use inkscape to do this? If not what program do you guys prefer and why?
Thanks again!
I think it all boils down to which software you are familiar with. Inkscape and Fusion 360, both which are free, will certainly do this. Others would use CorelDraw, Solid Edge(free), or whatever they are used to. I personally use Design Edge. Do you have a sketch you can provide to show us exactly what you are trying to accomplish of this particular project? If so, then share it here so we can take a look.
I think most drawing program will work fine as you can place the layers over each other for placement of tabs or where holes/slots need to go through.
Just like positioning bolt holes in different parts based on dimensional measurements.
acourtjester wrote: Sun Jul 10, 2022 10:30 pm I think most drawing program will work fine as you can place the layers over each other for placement of tabs or where holes/slots need to go through.
:Like :Like :Like
