Would someone do a tutorial
roberob2025
Post by roberob2025 »
Hello everyone I was wondering if anyone would be interested in doing a tutorial to show me how to take this image I am uploading from a jpeg to a vector file to a cut file from inkscape to fusion 360? I will pay you for your time. I just learn better by being showed and if I have questions to be able to ask as it is happening. I have been watching videos on how to use inkscape to trace bitmap but there always seems to be a step that is either not explained or I am just missing something because I cannot seem to get the end result I am looking for. If we could do like a screen sharing session for it. You can pm me and we can work out a time and price I would be greatly appreciate it. thank you. I will probably not be able to get back online until later tonight California time about 10 or 11pm. I will respond as soon as I get back online. Thank you again.
Re: Would someone do a tutorial
This appears to be a photograph of an embroidered patch. One thing to keep in mind here is that your auto trace will only be as good as your image fidelity. In this case, the outline appears wavy, some of the letters are slightly deformed, and the stars are not symmetric. So while an auto trace using Inkscape may be the first step, there is much more editing to be done to produce something usable for a quality plasma cut (or engraved, printed, etc.) part. I will send you a PM. I can't do it "real-time", but I am willing to spend some time showing you how to do this using a combination of Paint.net, Inkscape, and Fusion 360. I understand that some here could use Design Edge to accomplish this more quickly, but most folks don't have that luxury and you are wanting to learn how to fish, not simply asking someone to hand you a fish ready to cook.
roberob2025
yes all you said is correct. I very much do not want someone just to do it for me I want to learn the process from tying the knot for the hook adding bobbers, casting, reeling in, cooking, cleaning and everything else that goes into getting the fish to the diner plate! Thank you very much I appreciate it sincerely.
roberob2025 wrote: Wed Jun 15, 2022 1:34 pm yes all you said is correct. I very much do not want someone just to do it for me I want to learn the process from tying the knot for the hook adding bobbers, casting, reeling in, cooking, cleaning and everything else that goes into getting the fish to the diner plate! Thank you very much I appreciate it sincerely.
:Like :Like :Like
Rober I agree with David and would recommend limiting to Inkscape and paint until you get a little more under you belt. Trying to introduce more may end up confusing in the learning process. Many of the programs do similar things but using different names or processes to do the same thing which I think may hinder quicker learning. Another thing that may help is the search function here (upper right corner) to go back to earlier posts about Inkscape, There are many post where member help others with many screenshots showing processes for that members question. Sometimes having different sources helps to clear things quicker. When things start to make sense you will get a smile of your face, personal projects adds to the fun.
Joe Jones
Post by Joe Jones »
The very first thing you should do, is to sandwich that patch between two pieces of glass to flatten it out, and then take a photo of it.
Yes, this is an easy task in DesignEdge, but David is correct. It is pointless to show you how to do that using DesignEdge software if you do not have a PlasmaCam table. This photo has a lot wrong with it, and it is easily corrected in DesignEdge, but I am not the one to instruct people on Inkscape and other such programs, as I am admittedly probably MORE of an amateur on them than most people.
Another alternative is to find out WHO is making these patches, and get permission to acquire the file used to stitch the patch. I am fairly certain that could be used to create the file you want, without the wrinkles and distortions.
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
acourtjester wrote: Wed Jun 15, 2022 4:26 pm Rober I agree with David and would recommend limiting to Inkscape and paint until you get a little more under you belt. Trying to introduce more may end up confusing in the learning process. Many of the programs do similar things but using different names or processes to do the same thing which I think may hinder quicker learning. Another thing that may help is the search function here (upper right corner) to go back to earlier posts about Inkscape, There are many post where member help others with many screenshots showing processes for that members question. Sometimes having different sources helps to clear things quicker. When things start to make sense you will get a smile of your face, personal projects adds to the fun.
Tom - I talked to Rob last night and he does have a pretty good handle on Fusion 360, and showed me a few things about tracing with Fusion 360 that I had never seen before. His main problem was a few details about doing the auto trace with Inkscape. I think that now he's got it, and we did a sample part that worked out very well with the combination of Inkscape/Fusion 360. I will show the details here later when I get some time.
Good show :Like :Like :Like sounds like he will add to the collective knowledge of the site with a little time. :Yay
cstroke
Post by cstroke »
This game is such a kick in the nuts... It takes quite a bit of struggle and it's so rewarding when you get through the struggle..
Be patient and keep in mind every time you get frustrated you are learning something...
Good luck and stay with it..
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Here is the process we used to go from jpeg image to cut ready file using a combination of Inkscape and Fusion 360
Here it the jpeg image we started with.
I have created a "follow-on" thread showing how to do the "node editing" from within Fusion 360 as opposed to using Inkscape. I find this method quicker and easier to do.
viewtopic.php?f=51&t=34070&p=211478#p211478
Here is a tutorial I made sometime back showing tracing a drawing and making changes to the paths. near the end I show how to brake apart and join lines by using the node tools at the top of the page in Inkscape. Different from using the bezier tool to draw a new line to connect.
https://drive.google.com/file/d/1KBY2ts ... sp=sharing
acourtjester wrote: Fri Jun 17, 2022 9:28 am Here is a tutorial I made sometime back showing tracing a drawing and making changes to the paths. near the end I show how to brake apart and join lines by using the node tools at the top of the page in Inkscape. Different from using the bezier tool to draw a new line to connect.
:Like :Like :Like
There are many ways to do these things, and it never hurts to know some of the different approaches. Thanks for sharing your method Tom.
roberob2025
Sorry I have been busy the past few days. A very big thank you to David for talking to me on the phone the other day and helping get what I needed. And I have finally cut out the shark that we did together from Inkscape and fusion 360. I cut it with the primeweld cut60 ptm60 machine torch with 40 amp consumables at 33amps 60 psi 110 ipm pierce delay .75 pierce height .125 cut height .045. I think it turned out very good there was barely any dross and the lines are nice straight and very slight bevel. So thank you David I greatly appreciate you taking the time with me and enjoyed our phone conversation.
Rob - I think the shark turned out great! Nice clean looking cuts. Always happy to help when I can. I wonder if that front side dross is due to the part having water on it while cutting. Anyway, you are quite welcome.
big496
Post by big496 »
Thats what I call teamwork. Awesome! How do I acquire the help desk phone number :HaHa
big496 wrote: Sat Jun 25, 2022 11:46 pm Thats what I call teamwork. Awesome! How do I acquire the help desk phone number :HaHa
PM sent.
Plasma Spider collaboration strikes again, nice work guys :Like :Like
