Using a pen plotter with avid sheetcam
JeepGuy
Post by JeepGuy »
I got my pen plotter but in my version of sheetcam i only have plasma or drilling operations, anyone know how to get one i can use the pen plotter with?
Re: Using a pen plotter with avid sheetcam
Post by djreiswig »
I use my pen with a plasma operation. Just make a new tool. I think it's a marker tool. Then set the operation to have no leads and no offset.
I think you can also use it as a rotary tool with a very small diameter.
You can turn on the rotary operations in the options menu.
Yes you use a rotary tool in SheetCam no pierce or cut start needed only z movement to touch the paper surface and down about 0.10" and zero out the Z dro then run your g-code.
I sent you a DOC from the Google drive for you to download, it shows the setup steps.
Have fun
Tom
JeepGuy
Post by JeepGuy »
acourtjester wrote: Wed May 18, 2022 9:27 pm Yes you use a rotary tool in SheetCam no pierce or cut start needed only z movement to touch the paper surface and down about 0.10" and zero out the Z dro then run your g-code.
Have fun
Tom
I requested it from the link you sent
I just OKed the request, let me know if you still have a problem with the google link.
Return to “SheetCam”
