34by151 wrote: Sat May 14, 2022 5:41 pm
So your only going to run 4 of that 8 elements at any time (12Kw) not 24Kw?
You are on 240v power?
Correct.
You may need an extra SCR or Contactor as you are planning to run it at max current for hours at a time
I suspect it will burn out
Better to plan on the SCR/Contactor has double the current
What is an SCR/Contactor? The controller I purchased claims to be able to handle the load.
What is the internal dimensions of the oven?
Assuming its 4x4x8 12Kw would take a min of 30min to heat that volume
That's assuming no heat loss, so it would be more
The slower the oven gets to temp the longer it takes to get the parts to temp, its not a linear relationship
The interior is 4x4x75" tall, so I don't have to hunch over to walk into it. It will have a center shelf to divide the oven into two sections. That way, the top bank of burners would only heat 4x4x36" tall compartment, and the lower portion would not be heated at all.
I have the option of installing another controller, and running BOTH banks of burners to heat it up. That would be 100 AMPS of service for the warm up. Then when it gets to temperature, one bank can shut down, or I can run both banks simultaneously via two controllers.
Changing to 24Kw would bring that down to 13min
It would take 45Kw to get that down to 7min
Most ovens have the typical 4" wall thickness. My walls are 6" thick, and the ceiling and the door will also be 6" thick, all rock wool insulated. I will assume your calculations are correct, but the proof is in the pudding! I will have to put it through its paces to see the results.
You would be close at 24Kw and probably get good results on thin parts
Id be upping the heat source for thicker stuff
I live in a rural part of Kentucky. The single set of wires that runs across a neighbor's farm power three homes and four shops, for a total maximum of 1600 Amps of service divided among 7 buildings. Of course we are not all maxed out at all times, so I am not too worried about starving for power.
I have met other people with ovens. I respect your numbers, but I also see them doing magnificent powder coating jobs with far less than you claim I will require. So I will build this oven, with one,
or perhaps TWO controllers, and see what happens.
Look at it this way. If four burners aren't enough to cook a 4x4x75" oven efficiently, I can always build in a permanent shelf up off of the floor, to reduce the oven volume to calculated acceptable levels, and just use the space beneath for the wheels of a rolling cart to roll into, like an engine stand. I have back issues, so if the oven needs to be smaller, I will come up from the floor, rather than build a smaller oven that I need to bend down to access.
Robert is silent on this topic,
but I also respect his knowledge and experience. I would like to know if he concurs with your calculations, or if he stands somewhere BETWEEN "Easy Bake Oven" and "Nuclear Volcano."
I know that when a person gives advice, that advice
sometimes comes with a dash of "macho" for added flavor. For example, a woman asks about buying her first gun for self-defense. I can think of a dozen guys who would immediately tell her that she needs to carry a Desert Eagle with Black Talon loads, because
"...anything less isn't a REAL GUN." I tell her,
"Test different guns at a range, and buy, practice with, and carry the one that helps you HIT your target EVERY TIME. I would rather see you HIT an attacker three times with a .22LR, than MISS him three times with a .44 Magnum..." When someone talks about buying their first motorcycle, there is the
"..Anything under 1500 CC's is a toy!" crowd. I tell new riders,
"Try different bikes, and buy and ride the one that give you the most confidence and enjoyment, even if it is a scooter ..."
So I HEAR what you are saying about how this oven
should be built, but I also hear a bit of,
" ... if it can't roast an elephant in three minutes, it isn't a REAL powder coat oven." So the only way for ME to know, is to try it.
