45xp finecut ohmic question
mcmental
Post by mcmental »
good morning, i have jst put a set of finecut consumables into my 45xp machine torch and connected up the ohmic sensor but i cant get the tip to make the circuit? the deflector will complete but not the tip? ive cleaned them even though were brand new.
Re: 45xp finecut ohmic question
The defector is isolated from the tip and that is what should be contacting the metal not the tip
Tom is correct - the shield will make contact with the metal, not the nozzle. On another note, make sure you are using the FineCut swirl ring for best results.
mcmental
Post by mcmental »
Thanks again for your help, I rechecked everything and I had put the finecut hand torch deflecter on by mistake
mcmental wrote: Sun Mar 20, 2022 1:58 am Thanks again for your help, I rechecked everything and I had put the finecut hand torch deflecter on by mistake
Glad to hear you've got is sorted out.
After I posted I remembered on the 65 fine cut there are 2 different parts, one being the Deflector and the other is the shield.
Shield being the one used for Ohmic sensing, I should have been more clear in my post. :HaHa :HaHa
Which you did figure out. :Like
