looking for Help, willing to pay
Very new to this whole process and trying my best to learn it. Im trying to see if anyone can help me with this file. I want to cut it on a CNC plasma table. I cant figure out how to get it transitioned from Inkscape to sheetcam for cutting. Thanks guys
Re: looking for Help, willing to pay
Here is the dxf from an Inkscape auto trace. You would import your image file to Inkscape, then use "Path/Trace Bitmap" to convert to vector format, and finally export as dxf. Now open with Sheetcam to create your cut paths and g-code.
One other thing to point out is before you leave Inkscape you should put bridges to connect the closed loops in letters so they will not drop out. Unless you are going to cut the parts out for a layered sign. If you use the search function in the upper right you can find other posts here with tutorials on Inkscape showing how to do many things with Inkscape.
Hey man i appreciate that help. I guess my issue was not being able to get fine lines with trace bitmap and the cut outs were to close. This is great information, thanks buddy
We are always happy to help. Let us know how it turns out when you cut it.fragout08 wrote: Fri Jan 21, 2022 6:08 pm Hey man i appreciate that help. I guess my issue was not being able to get fine lines with trace bitmap and the cut outs were to close. This is great information, thanks buddy
