Hey guys,
If anyone has done some solidworks have you ever had this problem:
https://photos.app.goo.gl/4ncTh4GajJEdLaCp8
Now when using smart Dimensions if i click and drag out (to get a preview) nothing happens.
I need to click again which makes it hard to change where i am dimensioning.
Can't find an answer online etc. Thought you might have come accross it.
It was working perfectly for a long time, Somehow I have clicked something or pressed a shortcut button to change a setting and I can't get it back.
Solid Works
Re: Solid Works
Mine has always worked that way. I click on the line I want to dimension, drag it out, and then when I click the modify box appears directly over the dimension. But the dimension stays in the position I placed it without a problem. I enter the numerical dimension in the modify box and then click on the green check mark. I never know it worked any other way. Yes - it would be handy to have the modify box pop up next to the dimension, but not on top of it.
Re: Solid Works
I have pretty much switched from SolidWorks to Fusion 360. I find the Fusion 360 user interface much more intuitive and easy to use. Here is the same sequence of using the "smart dimension' tool. It pretty much does the same thing, placing the dimension modify box right on top of the dimension. I have never found this to be a problem.
Re: Solid Works
Steve - I actually just took another look at your video and I now understand your problem. Your modify box is popping up before you click. Here is the sequence of the same smart dimension and mine works fine. I am not aware of any setting that you may have changed that could cause this. If you are using a wireless mouse, try replacing your batteries. Or you might have a bad mouse with a "sticky" button. Try another mouse would be my suggestion.
Select the smart dimension tool and left click on the line to dimension.
Move the mouse pointer to position the dimension, then left click.
Select the dimension modification box and move so it is not on top of dimension text.
Enter the desired numerical dimension in the box and then click the green check mark to finish.
Re: Solid Works
thanks for the responses,
very strange I spent so long trying to fix the problem and now it has just gone back to working properly again....
No idea but i hope it doesnt happen again
Re: Solid Works
If you are using a wireless mouse, check your batteries. I have had similarly strange things happen when my batteries were low.Steveinmelb wrote: Fri Oct 29, 2021 11:51 pm thanks for the responses,
