I have a Primeweld CUt60S and it uses a PT60 torch, and i wondered if i can use any PT60 consumables ? since the primweld ones are 1.2mm witch is a bit to large for the small things i do. i seen some 0.8mm, and if you know of any smaller then that i would love to hear.
Like these
https://nl.aliexpress.com/item/32725649 ... 4c4d4VMZvB
i wondered if that should work ? and another question would my cutspeed go up or down ? i assume Up witch might be a problem but first i want to know if i am not destroying something
