Anti-Spatter Spray?
The-Meerkat
Anti-Spatter Spray?
Post by The-Meerkat »
I was reading some old posts. Jim Colt and Hypertherm recommend using a MIG Anti-Spatter spray or liquid to coat metal before plasma cutting. I’ve never used it but am considering doing so. I came across one made by Simple Green. Has anyone tried this product? What do you think about it? Is there another brand you recommend? I’ve read that people use everything from cooking anti-stick spray to some stuff called duck oil. I’m curious what’s working for folks out there.
Scott Meer
SeanP
Re: Anti-Spatter Spray?
Post by SeanP »
If I didn't use a water table something like that sounds ideal.
I only really spray the whole sheet if there is a lot of pierces on thick material do, it really does help reduce the slag pile, I have used duck oil before but now use AC-90, another thing I started using is cooking oil with a paint brush, quick dab on pierce points helps as well it's also great applied on the shield in fact I daub it on right up the retaining cap as well, it really helps to stop any spatter sticking to the shield, better than tip dip for mig welding I find.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
SeanP wrote: Sun Jul 11, 2021 10:34 am If I didn't use a water table something like that sounds ideal.
:Like :Like :Like :Like :Like
beefy
Post by beefy »
Sean,
don't know if I'm getting too nit picky here but does any type of cooking oil work, or have you always used one type.
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
WyoGreen
Post by WyoGreen »
Sean,
Keith
Well, you know Olive oil is supposed to be good for you, so if you inhale olive oil smoke it might also be good for you, besides giving the steel a nice soft feel :?: :?: :?: :roll:
Router
Laser
Post by djreiswig »
Peanut oil has a high smoke point, so maybe that would be better. Unless you're allergic to peanuts. :-?
SeanP
Post by SeanP »
Just checked and it's actually sunflower oil,,,,and no it's not a wind up - works well
Powermax XP45
Table build gallery
beefy
Post by beefy »
Cheers Sean,
well, if the smoke point temperature has anything to do with it, I Googled about oil smoke points and Rice Bran oil was pretty high up the list yet is one of the cheaper oils available in the supermarket.
Keith
LinuxCNC
Coreldraw 2019
Well you learn new things every day, I never heard of Rice Bran oil, well it does exist. :Like
MadMetal2000
Post by MadMetal2000 »
Check out this post from Craig Johnson back in 2013
https://plasmaspider.com/viewtopic.php? ... 270#p54269
cstroke
Post by cstroke »
I've used the simple green it works ok, Weld-kleen imo works better
https://www.amazon.com/Weld-Aid-Weld-Kl ... ial&sr=1-2
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Carlton
Post by Carlton »
I had a splatter problem and solved it to my satisfaction by cleaning the air supply, reducing the heat level and tinkering with the speed. My table is a water table, but I use it without water because for me the results are better. Yea, I know thats a bit odd. The way I cleaned up my air suppy is with two driers close to the compressor and an inline filter unit at the Plasma cutter (Lincoln 1000).
