Cutting Ar 400 steel
Giger1039
Post by Giger1039 »
The plasma cutter I am using can cut up to 3/8". (35amps) I am planning on cutting 3/8 ar400 with it. Will it cut the same as 3/8 mild steel? Sorry if the question seems stupid but never cut hardened steel before. I am planning on upgrading my cutter but I would like to know if I should before I waste some of a $611 plate! Thanks in advance!
Thor
Re: Cutting Ar 400 steel
Post by Thor »
IME it cuts the same
cutnweld
Post by cutnweld »
You may have to cut slower. Harder steel tends to have mag fields that can pull slag back up to kerf. Or so it seems to me. At least thats what I run into cutting 1" ar200 with my 85.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
Giger1039
Post by Giger1039 »
Awesome thanks guys
cstroke
Post by cstroke »
Yes, very similar IMO... Most of the time its the same every once in a while you have to cut slower depending on the batch..
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
bhamer62
Post by bhamer62 »
For laser cutting, we get it in pre blasted, most of your drossing will come from the skin on the underside of the material. If it still isn't being user friendly we slow it down to bout 80% or bump up the air pressure.
