6'x10' Retrofit
shaddr3
6'x10' Retrofit
Post by shaddr3 »
Hey guys, this is my first official appearance here though i've been scouring the forums for a year or so now, this is an amazing community!
I'm a fabricator/machinist, with experience building/retrofitting CNC equipment.
I'm in a local makerspace and we stumbled on this 1988 Esab Signmate Sign Router 6'x10' over the summer via CL. When we purchased it was 100% working but the tribe as spoken to retrofit to a plasma table. We currently have a Hypertherm 1650 mainly for the robot. The frame is very rigid, and we'll be modifying for a water bladder build. The gantry itself weighs around 250lbs bare, comprised of steel and aluminum. I'm trying to accomplish this retrofit within modest budget.
It uses a rack and pinion for the X&Y Axis, though unforunately only one per axis. I plan on upgrading the old DC Brushed servos & 40:1 gearbox with 1kW AC Brushless Servos (2000RPM CONT/3000 MAX), with a precision inline plentary gearbox (<3arcmin, 10:1), aiming for 1000-1500ipm rapids. The AC motors seem a bit overkill, but for $105 shipped for new servo and lightly used drive I couldn't refuse.
I haven't quite decided on the control software but i'm bordering Mach4 or Linux. I don't have much experience with Linux but others at the shop have extensive experience developing for the linuxcnc community. I'm also considering the Nuron Lite for our THC if we do go the Mach route.
My first goal is to get the XY axis moving and calibrated. I'm hoping the servo and drives arrive by the end of the week. I've acquired a AIA 4" Actuator w/ballscrew & DC Servo that im currently benchtesting for the Z axis.
shaddr3
Re: 6'x10' Retrofit
Post by shaddr3 »
Quick update. I decided against the 1kw servos, the seller was away for the holidays and I couldn't wait, plus the time involved bench testing them with the AB drives would have been too time consuming. I picked up two DYN4 750W Servos and H01 Drives, also made some adapters to the gearboxes using the original mounts. The original controls where mounted on the gantry itself with wiring from the power supply dangling off hooks to the side of the machine, this wasn't going to fly with the retrofit so I purchased a Gortrac cable carrier (metal) for the Y axis.
I started working on the controller which is mostly finished, I have yet to buy the NeuronLite. I'm using a PMDX 126 breakout board and an ESS motion controller. I think I went a little overboard. I'm hoping within the next week i'll be ready to benchtest the three axis. I scored a decent rackmount i7 desktop, along with a 24" touch screen LCD with articulating vesa mount from a local auction.
Originally I was going to use three phase for the build, but in case in the future if it ever gets moved or sold to a place with single phase, it'll hook right up without modifying connections to the drives.
Jesse
Re: 6'x10' Retrofit
Post by Jesse »
Hi shaddr3, A friend of mine found your post while researching for info on my table and I joined this awesome forum just to talk to you !
Sounds like you are in a league far above me but I am very interested in what you are doing, how it works and the like. I have I believe the exact same table, was used by the friend I mentioned earlier for routing plastics, styrofoam and other "soft" material. The mechanical hardware on this thing is mint because of that. I want to potentially do a complete retrofit to newer electronics. Are you still on here and willing to share ?
Jesse
shaddr3
Re: 6'x10' Retrofit
Post by shaddr3 »
Jesse, Sorry I didn't notice this until now.
Progress has been slow. We lost the space where we setup the table. I was able to take the table home, spent a good bit of summer cleaning and getting the room setup, installing 3/4 air lines in the shop, repairing an air dryer, the list goes on and on.... I don't have heat in the basement here so things have stalled though I have 99% of everything to put it together, including picking up a Powermax65 and machine torch. I'll update again in another month or two once this cold ends :?
I ended up ditching the PMDX126 and ESS, went with the Vital because of the better THC support. Neuron NEVER responded to any of my emails, nothing like they fell off the face of the earth. Now Warp has the THC in beta i'm told?
Re: 6'x10' Retrofit
You might look at PriceCNC AVHC10
shaddr3
Re: 6'x10' Retrofit
Post by shaddr3 »
It's been a long time since i've checked back here on the forums. I did go with the Hicon Integra (older blue model) and a Robot3T THC. By the time I had started finishing the controller this past March, Vital had released a new board with the new Mach4 screenset. Amazing how time flies and new technology is released before you can finish with the first... Anyways..
I was able to make a test cut last weekend out of some 3/8" plate. This is my first time using sheetcam, all hypertherm book settings. 2" circle came out 2.057". I have small electrical problem to work out with the ARC-OK signal from the THC, other than that electric is complete.
Next on the agenda is to lower the table a couple inches with hangers and fabricating a water table.
Still much much more learning to do but Finally Feels good to be in the club!! :)
manac
Re: 6'x10' Retrofit
Post by manac »
Looking good.
Much better than a router.
Re: 6'x10' Retrofit
Nice work! Your cut looks good, and I like your water tray.
Re: 6'x10' Retrofit
Nice job, looks great! Thanks for the update :Like
shaddr3
Re: 6'x10' Retrofit
Post by shaddr3 »
So I made some brackets on the table to drop it a couple inches. I fabricated a 7'x10' water table and slats, I rolled the inside with herculiner like requested from a couple guys in th facebook group. Yesterday I ran conduit and plumbed up the tank.
Re: 6'x10' Retrofit
This is definitely a "NO Nonsense" build. Very impressive. Keep up the good work!
