Hello, I'm a newbie here. I got a few questions about hooking my TD60i to my premier plasma table.
I used the search function on here and came up with conflicting information, some say you need the automation card some say you do not?
I'm looking to get everything I need before my table is delivered so I am ready to cut asap.
I have the sl60 hand torch now, is the sl100 worth spending the money on, is there advantages?
Thanks Dan
TD 60i and premier plasma
Re: TD 60i and premier plasma
I would get the Automation interface. Life will be easier and safer if you do.
I would also get the machine torch. The machine senses the difference between the hand torch and the machine torch so you will need to modify your hand torch to trigger it. I wish I had a hand torch to go with My A120 with an SL100
