Lead in help
Lead in help
I can't seem to move the lead ins on certain files from the outside of the part to the inside. This is making it impossible to cut artwork. I have tried changing the offset to inside, and also none. I have also tried playing with the lead in lengths. I also have selected to start in the center of a circle less than 5 inches but the torch will still lead in from the outside and destroy the part. Is this an issue with the files I'm getting off the internet? Some files seam to cut ok but most not. I have tried making several test files of circles and triangles of different sizes and still cant make it perform correctly. Does anyone know what I'm doing wrong? I'm a new user and would appreciate any help with this.
Re: Lead in help
If you have problems with offsets being on the correct side you most likely have an open path. I'm not sure what program you are using, but that's usually the problem when I run into this behavior in SheetCam.
Re: Lead in help
It is hard to say with files obtained on the internet. Presumably these internet files are in dxf format, and as djreiswig pointed out you may have open paths and/or overlaps. But if you are creating your own circles and triangles and still can't place the lead-in and/or cut path either at the inside or outside of the circle or triangle, then that sounds like a problem with your CAM program. What programs or programs are you using to draw your parts and create your cut paths?matthewkaye@live.com wrote: ↑Sat Oct 31, 2020 11:24 am I can't seem to move the lead ins on certain files from the outside of the part to the inside. This is making it impossible to cut artwork. I have tried changing the offset to inside, and also none. I have also tried playing with the lead in lengths. I also have selected to start in the center of a circle less than 5 inches but the torch will still lead in from the outside and destroy the part. Is this an issue with the files I'm getting off the internet? Some files seam to cut ok but most not. I have tried making several test files of circles and triangles of different sizes and still cant make it perform correctly. Does anyone know what I'm doing wrong? I'm a new user and would appreciate any help with this.
Re: Lead in help
I checked out the Arclight Dynamics website and the demonstration videos show drawings being created in both Inkscape and SolidEdge CAD and then exported as dxf files and imported to Sheetcam for creating cut paths. I do not use Sheetcam, but I suspect that the problems Matthew is having are related to some particular Sheetcam settings.
There may also be a specific Sheetcam post processor for Arclight Dynamics Command CNC which if not installed might be causing these problems.
https://arclightcnc.com/how-to-draw-pro ... ut-a-part/
Re: Lead in help
I'm using Sheetcam. I tried drawing some simple triangles and circles and still couldn't move the lead in to the inside.
Re: Lead in help
By open path do you mean and open line in the drawing?
Re: Lead in help
Yes. A circle is a closed path, but a circle with a portion missing is an open path. A straight line would be an open path, but a square would be a closed path. I don't think your problem is with open/closed paths, but more the procedure/settings you are using to create your cut paths. If you watch the video I posted above, it should hopefully explain the proper procedure for creating cut paths and lead-ins in Sheetcam. I am not a Sheetcam user, but perhaps some who is will chime in here.matthewkaye@live.com wrote: ↑Sun Nov 01, 2020 10:00 pm By open path do you mean and open line in the drawing?
Re: Lead in help
When you're creating an Operation, the first box is which offset you prefer. 99% of the time you want Outisde offset. This automatically cuts outside exterior (red) contrours, and inside interior (yellow) contours. If you are trying to flip start point directions, change your offset.
