Trying to convert a picture of an image to DXF with Inkscape
Hello!
I am still new and learning how to use Inkscape for converting an image to a DXF file. I was able to get the picture traced/converted in Inkscape but when I loaded it to Fusion 360 not all of the image will extrude correctly in order to cut. Attached is the picture I loaded to Inskcape and the DXF I was able to produce but will not extrude correctly.
Any tips/tricks on are greatly appreciated!
Thank you!
Jennifer
Thank you!
Jennifer
Re: Trying to convert a picture of an image to DXF with Inkscape
HI Jennifer,
I don't know how to use Inkscape, but I think your dxf file just needed to be linked (joined) into continuous closed paths. When I opened your dxf file, it looked like this with many individual paths (short line segments not linked to each other). Each red dot is an intersection between two individual paths.
After linking/joining it looks like this.
Now when imported into Fusion 360, the cut paths look like this.
As drawn, the wings and the nut are 3 separate pieces. You could edit your Inkscape file and join them together before exporting as a dxf to create a single part.
I find it odd for people who want to cut things with plasma thinking the DXF file needs to be extruded. Plasma cutting is a 2-D function,no depth needed, a DXF file from Inkscape cuts very well as long as it planned as needed, no dropouts, and alike. I am not anti-extrude as I use it for creating STL files for 3-D printing.
Extruding a 2D DWG / DXF / vector
its probably an easy way of checking if the pattern is closed...... if it extrudes its a closed loop, if not.... you have an open loop
Thank you! I thought that maybe the problem but was having trouble figuring how to fix it! I still have a lot to learn as this is all very new to me! I really appreciate your help and advise! This puts me on the right path for future file conversions! Thanks again!
adbuch wrote: Fri Jun 19, 2020 2:13 am HI Jennifer,
Winged Nut as single part.dxf
I think it depends on the CAM program. I certainly don't need to extrude a dxf to cut with Design Edge. Perhaps Fusion 360 is different.acourtjester wrote: Fri Jun 19, 2020 9:20 am I find it odd for people who want to cut things with plasma thinking the DXF file needs to be extruded. Plasma cutting is a 2-D function,no depth needed, a DXF file from Inkscape cuts very well as long as it planned as needed, no dropouts, and alike. I am not anti-extrude as I use it for creating STL files for 3-D printing.
My 3D solid modelling software creates 2D drawings from 3D parts you make. You can't simply make a 2D drawing and convert to DXF. Therefore I must first extrude a 2D sketch in order to get my 2D drawing/DXF.adbuch wrote: Fri Jun 19, 2020 6:29 pmI think it depends on the CAM program. I certainly don't need to extrude a dxf to cut with Design Edge. Perhaps Fusion 360 is different.acourtjester wrote: Fri Jun 19, 2020 9:20 am I find it odd for people who want to cut things with plasma thinking the DXF file needs to be extruded. Plasma cutting is a 2-D function,no depth needed, a DXF file from Inkscape cuts very well as long as it planned as needed, no dropouts, and alike. I am not anti-extrude as I use it for creating STL files for 3-D printing.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Jennifer,
I use Coreldraw and whenever I import a DXF all nodes are "UN-JOINED", so if there's a 1000 nodes in a drawing, there's also around the same number of separate objects. I have to select everything and use the join nodes function to connect them all.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Apparently extrusion is not a prerequisite for plasma cutting with Fusion 360. But I agree with Robert, it does provide an easy method of verifying that you have closed paths. When Jennifer's original dxf file was imported into Fusion 360, is consisted of many small individual segments and may have been harder to work with.
Keith,beefy wrote: Fri Jun 19, 2020 8:37 pm Jennifer,
Do you happen to know if Fusion 360 has a "join nodes" function?
Hi Jennifer,watovametalworks wrote: Fri Jun 19, 2020 11:21 am Thank you! I thought that maybe the problem but was having trouble figuring how to fix it! I still have a lot to learn as this is all very new to me! I really appreciate your help and advise! This puts me on the right path for future file conversions! Thanks again!
I was happy to help! Please let us know how your project turns out.
Sorry David,adbuch wrote: Fri Jun 19, 2020 9:03 pmKeith,beefy wrote: Fri Jun 19, 2020 8:37 pm Jennifer,
I've never used Fusion 360. I use Alibre Design.
Keith
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
With all things we use the things that we learn and like to do the thing we need to do.
For 3-D I use TurboCad for the 2-D then on to 123D Design for the 3-D parts (stl files) Works great for me, happy yours does what you want too. Want to get into Fusion 360 just not had the time yet.
I'm not a big Fusion 360 user, but I know the basics. It's a free program, so maybe take a look at it in your spare time. My 3d stuff is usually either SolidWorks or MasterCAM. Yes - I usually use what I know and am familiar/comfortable with.acourtjester wrote: Fri Jun 19, 2020 11:19 pm With all things we use the things that we learn and like to do the thing we need to do.
Robert posted this in another post and it seems to show the differences in the software we use
How did all this talk about being right/wrong start.
Where in this thread has anyone suggested someone else is wrong.
All I've seen is suggestions on where a problem may lie, i.e. others trying to help.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Keith,beefy wrote: Sat Jun 20, 2020 7:40 pm How did all this talk about being right/wrong start.
I would tend to agree with you. The previous post makes no sense to me and has nothing to do with the original topic.
