Need Help
Kkc10890
Need Help
Post by Kkc10890 »
I am trying to get this into a dxf for my torchmate and can't figure out how to get it to cut correctly. I have a round piece of metal that is 24 by 24 to cut it out of. Any help will be greatly appreciated.
beefy
4.5 Star Member
4.5 Star Member
Re: Need Help
Post by beefy »
If you are just looking for someone to convert if for you and give you a cut ready DXF, the forum rules for this section list several members that do paid conversions:
viewtopic.php?f=98&t=27175
You are actually supposed to show what you have attempted, what is going wrong, etc. Your very first post and it sounds like you are just asking someone to do it for you.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Re: Need Help
Plus it's not readily traceable as is. I think it will take a little bit of work to create the cut file for this part.
Re: Need Help
Given the quality of the photo, this is the best I could come up (in a limited amount of time) with from a trace of the image. I'm pretty sure one of the "hired guns" could do much better. I guess you get what you pay for.
Re: Need Help
If the OP is willing to plunk down the 40 bucks for the LightBurn software, he could trace the image posted above and start cutting.
Re: Need Help
I've seen people that could cut one like adbuch posted with a hand torch. No sense wasting a CNC on that,, but if you want a clean and crisp part paying the few dollars that one of the guys/girls on here would charge and cut it with your CNC it would look GREAT!
robertspark
Re: Need Help
Post by robertspark »
adbuch wrote: Sat Jun 13, 2020 5:37 am If the OP is willing to plunk down the 40 bucks for the LightBurn software, he could trace the image posted above and start cutting.
Is that what you are using?
I don't get on well with inkscape.... Seems to take ages.... Guess I'm just looking for a shortcut....
Re: Need Help
robertspark wrote: Sat Jun 13, 2020 12:36 pm
Hi Robert,
I used Design Edge to import/trace/edit the original photo posted by the OP. What I meant was that now that I have posted this clean image:
The OP could use LightBurn (or perhaps inkscape - which I have never used) to import and trace my posted image and then export it as a dxf file to achieve his desired end result.
beefy
4.5 Star Member
4.5 Star Member
Re: Need Help
Post by beefy »
Just spent a couple of hours drawing it up from scratch in Coreldraw.
Brought as a DXF into Sheetcam and a nice clean cut path file generated (attached photo).
If you are interested in the DXF, you can pay me $40 Australian via Paypal and it's yours. If not, no problem, I needed to refresh a little.
LinuxCNC
Coreldraw 2019
Re: Need Help
Nice work!! Well worth $40 Australian.
tinspark
Re: Need Help
Post by tinspark »
Or purchase LightBurn for $40 as David mentioned a few posts up and learn it and be off and running........
Or watch a few Youtube videos and use Inscape for free.....
Lots of stuff out there if someone wants to take a few evenings and just learn it..
IMHO :)
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Kkc10890
Re: Need Help
Post by Kkc10890 »
Thanks all. I am using Torchmate Cad software and have been for a couple of years. I appreciate all the advice and help. I'm still learning, so I greatly appreciate all the input.
tinspark
Re: Need Help
Post by tinspark »
We are all on different levels of learning ..
We gotta stay curious, and never be afraid to fail... Lord knows I have done my share :)
“The important thing is not to stop questioning; curiosity has its own reason for existing.” – Albert Einstein
Doug,
Hypertherm 45XP-
Re: Need Help
Kkc10890 wrote: Sun Jun 14, 2020 8:46 pm Thanks all. I am using Torchmate Cad software and have been for a couple of years. I appreciate all the advice and help. I'm still learning, so I greatly appreciate all the input.
I sent you a PM.
Re: Need Help
tinspark wrote: Sun Jun 14, 2020 8:35 pm Or purchase LightBurn for $40 as David mentioned a few posts up and learn it and be off and running........
IMHO :)
Unfortunately, the original OP supplied image did not convert/trace using LightBurn to achieve a usable result. Original image on left, traced dxf on right.
I ended up importing into Design Edge with better results (after much experimenting). I still had to spend a bit of time editing. I'm no expert here, still learning.
tinspark
Re: Need Help
Post by tinspark »
This was my conversion with inkscape.
Not super clean but down and dirty and took maybe 5 minutes max to convert to DXF.
The OP's picture has a lot of extra nodes because of the grassy background
I would typically take this into DesignEdge as a DXF to clean up, which may take an hour or more depending on the level of neatness required
The sawblade would need redrawing. but in this case, I would consider deleting it and adding a clean one that I have on file.
Also, There is a nicer round barbed wire file that I had seen on this site. I'd offer the customer that one, which IMHO looks a lot better than the original one. Looks, too thick, kinda like a rope with barbs..just saying....:-)
Doug,
Hypertherm 45XP-
Re: Need Help
Doug,
This was my basic conversion using Design Edge (before any editing). I think it looks about the same as yours. I don't know how to use Inkscape, so I am using what I have.
