Another flag - line problem
smcmurrey
Post by smcmurrey »
I'm having trouble in getting this flag right in Sheetcam. All the lines are trying to close or it adds the arc at the end. Everything was on 1 layer using no offset. I tried adding a few lines to a new layer but the same thing happens. The dxf looks fine in F360, QCAD, and DraftSight. Any idea what I'm doing wrong?
Re: Another flag - line problem
Post by djreiswig »
Does your drawing contain splines? SheetCam doesn't work well with splines. Convert the splines to polylines and it should work better.
smcmurrey
Post by smcmurrey »
Thanks for the suggestion but the lines are polyline in QCAD and DraftSight.
Post by djreiswig »
I'm not sure then. That's exactly what it looks like when I download a file with splines.
beefy
Post by beefy »
If you are not worried about others getting your pattern then attach the DXF or SVG file you imported into Sheetcam.
It's much easier to see what's happening when others can check your file directly.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Les Newell
Post by Les Newell »
The problem does appear to be a bug in SheetCam Stable. Stanton sent me some files to test off-list and the problem is triggered by using overcut on open paths. SheetCam is trying to overcut back to the start of the line and getting horribly confused in the process. The development version of SheetCam correctly ignores overcut in this case.
smcmurrey
Post by smcmurrey »
Thanks for the help guys!
Return to “SheetCam”
