I have jobs saved in Sheetcam that are 4x4 sheets nested with several different parts that have been duplicated or arrayed. I would like to rotate the entire sheet of nested parts in one action but all I know how to do is one part at a time. I have about a dozen different nests saved and this is far too time consuming.
Is there a way to rotate the entire sheet of parts?
Some parts have long cuts that occasionally line up with the slats and cause cut issues thus, I want to rotate the entire sheet 90 deg to reduce the issue.
Any ideas?
Rotating an Entire Nest
- Ironken
JD2 MAD 4X4
Millermatic 252 (spray)
Millermatic 190 (short circuit)
Syncrowave 210
Powermax 65
Powermax 45xp
Grizzly Vertical Mill (junk)
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Re: Rotating an Entire Nest
You could probably accomplish this by editing your post processor and swapping the x and y moves.
- Ironken
Good idea DJ....I'll take a chop at it. Thank you.djreiswig wrote: Wed Nov 13, 2019 8:23 pm You could probably accomplish this by editing your post processor and swapping the x and y moves.
JD2 MAD 4X4
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
In nesting mode use your mouse to drag a box over all of the parts. That selects all parts. Now use the < and > keys to rotate the group. You can also drag the group around if you need to reposition them.
- Ironken
Thank you Les. I always selected with the box and entered the degrees making only the original part rotate. Ill try the arrows.Les Newell wrote: Thu Nov 14, 2019 6:41 am In nesting mode use your mouse to drag a box over all of the parts. That selects all parts. Now use the < and > keys to rotate the group. You can also drag the group around if you need to reposition them.
JD2 MAD 4X4
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
I'll have to remember that. I didn't know you could select multiple parts at once.Les Newell wrote: Thu Nov 14, 2019 6:41 am In nesting mode use your mouse to drag a box over all of the parts. That selects all parts. Now use the < and > keys to rotate the group. You can also drag the group around if you need to reposition them.
If you hold the <ctrl> key and click on multiple parts you can select them that way as well. Useful if you want to only move/rotate a few parts.
As usual you never stop learning, thanks Les, once again we see what a great software package you have developed.
I was not sure about doing this (the dummy I am
) so I followed your instructions and wala slam dunk,
here are 2 screen screenshots.
