I was hoping somebody could fill me in on the approved process of tightening belts on a dynatorch super-b. I’ve had it for around 6 months and it’s always cut perfect. Although lately I’ve noticed the belts are quite a bit looser than the book says they should be. It says pulling the belt tight in the middle with the gantry at home position should cause approximately 1” of gap between the belt and the table. Mine is probably closer to 3 inches!
Like I said it still cuts just as it always has, but I am anticipating having to tighten these belts at some point, and when I do I don’t want to end up throwing anything out of wack. I’ve read that a machine needs to be “re-calibrated” anytime you mess with the belt tension. Could anyone give me a little insight on this? Thanks!
Bow Hunter Antler Design
Download Design
Question about belt tension
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- Welcome Center and Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design and Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table and Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Tracker CNC Forum
- ↳ Tracker CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- CAD-CAM and Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories and Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
