Painting Engravings
Trae Reed
Painting Engravings
Post by Trae Reed »
What is everyone doing to paint engravings? I just started engraving and want to see what others are doing to make things pop. Thanks, Trae
Re: Painting Engravings
Post by tnbndr »
I typically paint over the piece, let the paint dry and then grind off all the paint leaving just paint in the deep engraving.
I also use machinists dye, but typically only come in red and blue.
Trae Reed
Post by Trae Reed »
That's what I did and it turned out awesome, Thank you for the help!!
