Cut image inside of a pre-existing material shape
Searchman
Post by Searchman »
Is there a way to set up Sheetcam to cut within a material shape that is not rectangle or square?
For instance round.
SegoMan DeSigns
Re: Cut image inside of a pre-existing material shape
Post by SegoMan DeSigns »
What I do in a cut like this is to layout the perimeter to match the existing object then insert what you want to cut out of it. Turn off the torch and do a couple of dry runs to align things. Once aligned turn on the torch and start cutting when the ID is cut pause the machine and remove the plate.
Return to “SheetCam”
