Hey guys, Started this table about a year ago and it's finally coming close to it's completion!
I'll walk you guys a bit through the specs.
Eastwood Versacut40 plasma cutter
Currently running NEMA 23's on a direct GT2 belt drive (I'll explain)
DM542A Drivers
Mesa 7196 Controller (in the mail)
Proma 150 THC (also in the mail)
Z axis is an openbuilds 250mm c-beam linear actuator (not currently installed as I mount the floating torch/ohmic sensor)
Frame is comprised of 2x4 tube w/ 1/2" (IIRC) angle on edge with steel v-wheels & 2x2 tube legs.
I'll be running linuxcnc 2.8 (Master) from an old laptop. I've tried to make the controller as plug and play as possible, I'd like to integrate an ohmic sensor ASAP.
Okay so, let's address the obvious... Why is there such a mish-mash of decent equipment and crap equipment.
Let's just say "be careful who you go into business with"; partner basically pulled his funding for equipment like rack and pinion, linear rails...etc. leaving me to compromise on belt drive and v-wheels... and then complained that it didn't look sturdy enough... </rant> This also explains the layout of the table.
I'm resolved that the next plasma table will be well designed and implemented and represent good value.
I'm looking forward to working with you all, learning a lot and hopefully paying the favour forward. Because my table isn't currently running, the first order of business is learning.
I'm in the middle of fabricating a gate, some parts of which are covering the table.
First Table 5x10 NEWBIE!
1 post
• Page 1 of 1
Post by snugglylovemuffin »
1 post
• Page 1 of 1
Jump to
- Welcome Center and Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design and Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table and Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Tracker CNC Forum
- ↳ Tracker CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- CAD-CAM and Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories and Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
