Bigger Screen For Mach3
Here is a way to enlarge the viewing screen in Mach 3 many already know about this but I thought I would pass it on :lol:
I bought a screenset for routers and the guy told me how to do it. You start Mach 3 a normal and then enlarge the outside window that Mach is in.
The Mach display will stay the same but the window is larger. Go into config and the general config and down the bottom there is a small check box for Auto screen enlarge put a check in it. Then exit Mach 3 and then restart it, the display will now fill the outer window frame :D
little blue choo
Re: Big Screen
Post by little blue choo »
Good to know. Thanks acourtjrester
Rick
Rick
Arclight 9600 4x8 table
RAD
Re: Big Screen
Post by RAD »
Was looking for a way to do this, thanks
D.I.Y 4x4 CNC Plasma Table with water tray
60 Gal. A/C + D.I.Y Aftercooler + Water/Oil seperator + Desicant air dryer
45XP (CPC with hand torch)
MiniTHC
UCCNC + Sheetcam + Inkscape / AutoCAD
SeanP
Re: Big Screen
Post by SeanP »
Never knew that, I made my own screenset to fit my monitor, tried plenty of times before to make it fit, thanks for passing it on.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
